Ana içeriğe geç
Nook HD+ Antenna Replacement
Neye ihtiyacın var
    1. Nook HD+ Antenna Replacement, Antenna: adım 1, 1 resimden 1.
      • Pry the front frame off of the nook by wedging the plastic opening piece between the frame and the nook.
      FixBot'a Sor
      Yorum Ekle
    2. Nook HD+ Antenna Replacement, Remove the screws: adım 2, 2 resimden 1. Nook HD+ Antenna Replacement, Remove the screws: adım 2, 2 resimden 2.
      • Remove every visible screw from the front of the nook using the T-4 attachment for the screwdriver in the iFixit screwdriver kit.
      FixBot'a Sor
      Yorum Ekle
    3. Nook HD+ Antenna Replacement, Remove the chassis: adım 3, 2 resimden 1. Nook HD+ Antenna Replacement, Remove the chassis: adım 3, 2 resimden 2.
      • Carefully remove the center chassis from the bottom frame.
      FixBot'a Sor
      Yorum Ekle
    4. Nook HD+ Antenna Replacement, Dettatch battery: adım 4, 3 resimden 1. Nook HD+ Antenna Replacement, Dettatch battery: adım 4, 3 resimden 2. Nook HD+ Antenna Replacement, Dettatch battery: adım 4, 3 resimden 3.
      • Detach the battery ribbon from the motherboard.
      FixBot'a Sor
      Yorum Ekle
    5. Nook HD+ Antenna Replacement, Flip the center chassis: adım 5, 1 resimden 1.
      • Flip the center chassis so that the screen is facing down, and the hole is positioned in the bottom right corner.
      FixBot'a Sor
      Yorum Ekle
    6. Nook HD+ Antenna Replacement, Remove the antenna part 1: adım 6, 2 resimden 1. Nook HD+ Antenna Replacement, Remove the antenna part 1: adım 6, 2 resimden 2.
      • Remove the wire from the attachment on the motherboard (this wire un-clips).
      FixBot'a Sor
      Yorum Ekle
    7. Nook HD+ Antenna Replacement, Remove the antenna part 2: adım 7, 2 resimden 1. Nook HD+ Antenna Replacement, Remove the antenna part 2: adım 7, 2 resimden 2.
      • Apply soldering iron to the wire where it connects on the frame side. Remove wire when the solder is molten.
      FixBot'a Sor
      Yorum Ekle
    8. Nook HD+ Antenna Replacement, Place new antenna.: adım 8, 2 resimden 1. Nook HD+ Antenna Replacement, Place new antenna.: adım 8, 2 resimden 2.
      • Replace new antenna following all the steps in reverse.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Elijah Gonsalves
1.049 İtibar
3 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 2-3, Duarte Fall 2014 UMass Dartmouth, Team 2-3, Duarte Fall 2014 üyesi
UMASSD-DUARTE-F14S2G3
5 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 12
Son 30 gün: 32
Her zaman: 1,457
