Ana içeriğe geç
Nook HD+ Battery Replacement
Neye ihtiyacın var
  1. Nook HD+ Battery Replacement, Remove the front frame: adım 1, 3 resimden 1. Nook HD+ Battery Replacement, Remove the front frame: adım 1, 3 resimden 2. Nook HD+ Battery Replacement, Remove the front frame: adım 1, 3 resimden 3.
    • Wedge the plastic opening piece underneath the bottom left hand corner of the front frame. Pry the frame off of the Nook.
    FixBot'a Sor
    Yorum Ekle
  2. Nook HD+ Battery Replacement, Remove the screws: adım 2, 2 resimden 1. Nook HD+ Battery Replacement, Remove the screws: adım 2, 2 resimden 2.
    • Remove every visible screw tying the chassis to the bottom frame using the T-4 attachment for the screwdriver in the iFixit screwdriver kit.
    FixBot'a Sor
    Yorum Ekle
  3. Nook HD+ Battery Replacement, Remove the chassis: adım 3, 1 resimden 1.
    • Carefully remove center chassis from bottom frame.
    FixBot'a Sor
    Yorum Ekle
  4. Nook HD+ Battery Replacement, Detach battery: adım 4, 3 resimden 1. Nook HD+ Battery Replacement, Detach battery: adım 4, 3 resimden 2. Nook HD+ Battery Replacement, Detach battery: adım 4, 3 resimden 3.
    • Detach the battery ribbon from the motherboard.
    FixBot'a Sor
    Yorum Ekle
  5. Nook HD+ Battery Replacement, Remove the battery: adım 5, 2 resimden 1. Nook HD+ Battery Replacement, Remove the battery: adım 5, 2 resimden 2.
    • Pry battery off of bottom frame using plastic opening tool.
    FixBot'a Sor
    Yorum Ekle
  6. Nook HD+ Battery Replacement, Place new battery: adım 6, 1 resimden 1.
    • Apply glue to the bottom side of new battery. Re-insert new battery onto bottom frame and allow to dry. Follow steps in reverse to put nook back together.
    FixBot'a Sor
    Yorum Ekle
Sonuç
12 farklı kişi bu kılavuzu tamamladı.
Elijah Gonsalves
1.049 İtibar
3 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 2-3, Duarte Fall 2014 UMass Dartmouth, Team 2-3, Duarte Fall 2014 üyesi
UMASSD-DUARTE-F14S2G3
5 Üyeler
10 adet Kılavuz yazıldı
6Kılavuz Yorumları
Does model affect battery type? The replacement battery was stated so I'm just curious
Jon - Yanıt Paylaş
Where i can buy new battery, or any similar [6000 mAh] ?
Sebastian kukosh - Yanıt Paylaş
Anyone have a lead on good batteries?
omarhani - Yanıt Paylaş
clear directions, liked this guide
wandat100 - Yanıt Paylaş
i have a Barnes and noble nook HD+ and how it won't charger at all.
Tina Brown - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 12
Son 30 gün: 55
Her zaman: 10,608
