Ana içeriğe geç
Nook HD+ Battery Replacement
Neye ihtiyacın var
  1. Nook HD+ Battery Replacement, Remove the front frame: adım 1, 3 resimden 1. Nook HD+ Battery Replacement, Remove the front frame: adım 1, 3 resimden 2. Nook HD+ Battery Replacement, Remove the front frame: adım 1, 3 resimden 3.
    • Wedge the plastic opening piece underneath the bottom left hand corner of the front frame. Pry the frame off of the Nook.
  2. Nook HD+ Battery Replacement, Remove the screws: adım 2, 2 resimden 1. Nook HD+ Battery Replacement, Remove the screws: adım 2, 2 resimden 2.
    • Remove every visible screw tying the chassis to the bottom frame using the T-4 attachment for the screwdriver in the iFixit screwdriver kit.
  3. Nook HD+ Battery Replacement, Remove the chassis: adım 3, 1 resimden 1.
    • Carefully remove center chassis from bottom frame.
  4. Nook HD+ Battery Replacement, Detach battery: adım 4, 3 resimden 1. Nook HD+ Battery Replacement, Detach battery: adım 4, 3 resimden 2. Nook HD+ Battery Replacement, Detach battery: adım 4, 3 resimden 3.
    • Detach the battery ribbon from the motherboard.
  5. Nook HD+ Battery Replacement, Remove the battery: adım 5, 2 resimden 1. Nook HD+ Battery Replacement, Remove the battery: adım 5, 2 resimden 2.
    • Pry battery off of bottom frame using plastic opening tool.
  6. Nook HD+ Battery Replacement, Place new battery: adım 6, 1 resimden 1.
    • Apply glue to the bottom side of new battery. Re-insert new battery onto bottom frame and allow to dry. Follow steps in reverse to put nook back together.
Sonuç
12 farklı kişi bu kılavuzu tamamladı.
Elijah Gonsalves
1.049 İtibar
3 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 2-3, Duarte Fall 2014 UMass Dartmouth, Team 2-3, Duarte Fall 2014 üyesi
UMASSD-DUARTE-F14S2G3
5 Üyeler
10 adet Kılavuz yazıldı
5 Yorum
Does model affect battery type? The replacement battery was stated so I'm just curious
Jon - Yanıt
Where i can buy new battery, or any similar [6000 mAh] ?
Sebastian kukosh - Yanıt
Anyone have a lead on good batteries?
omarhani - Yanıt
clear directions, liked this guide
wandat100 - Yanıt
i have a Barnes and noble nook HD+ and how it won't charger at all.
Tina Brown - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 51
Her zaman: 9,469
