Ana içeriğe geç
Nook HD+ Motherboard Replacement
Neye ihtiyacın var
  1. Nook HD+ Motherboard Replacement, Motherboard: adım 1, 3 resimden 1. Nook HD+ Motherboard Replacement, Motherboard: adım 1, 3 resimden 2. Nook HD+ Motherboard Replacement, Motherboard: adım 1, 3 resimden 3.
    • Open the plastic frame by wedging the plastic iFixit opening tool under the plastic frame to remove adhesive.
    • Pop up all plastic tabs that secure the frame to the chassis.
  2. Nook HD+ Motherboard Replacement: adım 2, 3 resimden 1. Nook HD+ Motherboard Replacement: adım 2, 3 resimden 2. Nook HD+ Motherboard Replacement: adım 2, 3 resimden 3.
    • Remove twenty 5.0 mm Torx T5 screws that hold the chassis to the back casing using a screwdriver.
    • Disconnect battery from motherboard.
    • Remove back casing.
  3. Nook HD+ Motherboard Replacement: adım 3, 2 resimden 1. Nook HD+ Motherboard Replacement: adım 3, 2 resimden 2.
    Bu adımda kullanılan alet:
    Satın Al
    • Disconnect both ribbons from the motherboard by pulling up on the dark grey flaps and pulling out the ribbons.
    • Use tweezers to lift the flaps.
  4. Nook HD+ Motherboard Replacement: adım 4, 1 resimden 1.
    • Disconnect the small red and black ribbon connected to the speaker from the white clip on the motherboard.
    • No tool is needed. Gently pull on the wires until the piece disconnects.
  5. Nook HD+ Motherboard Replacement: adım 5, 1 resimden 1.
    • Disconnect antenna from motherboard by pulling up with slight force.
  6. Nook HD+ Motherboard Replacement: adım 6, 2 resimden 1. Nook HD+ Motherboard Replacement: adım 6, 2 resimden 2.
    • Remove two 5.0 mm Torx T5 screws attached to the motherboard using a screwdriver.
    • Lift the small foam piece attached to the black strip on the motherboard and gently pull up.
  7. Nook HD+ Motherboard Replacement: adım 7, 2 resimden 1. Nook HD+ Motherboard Replacement: adım 7, 2 resimden 2.
    • With the black strip lifted, carefully snap the motherboard out of the plastic pieces holding it down.
    • Remove the motherboard.
Sonuç
Brennan Holcombe
256 İtibar
2 adet Kılavuz yazıldı
Ekip
IUPUI, Team 3-3, Harley Spring 2022 IUPUI, Team 3-3, Harley Spring 2022 üyesi
IUPUI-HARLEY-S22S3G3
3 Üyeler
3 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 6
Her zaman: 252
