Ana içeriğe geç
Nook HD+ Motherboard Replacement
Neye ihtiyacın var
    1. Nook HD+ Motherboard Replacement, Motherboard: adım 1, 3 resimden 1. Nook HD+ Motherboard Replacement, Motherboard: adım 1, 3 resimden 2. Nook HD+ Motherboard Replacement, Motherboard: adım 1, 3 resimden 3.
      • Open the plastic frame by wedging the plastic iFixit opening tool under the plastic frame to remove adhesive.
      • Pop up all plastic tabs that secure the frame to the chassis.
      FixBot'a Sor
      Yorum Ekle
    2. Nook HD+ Motherboard Replacement: adım 2, 3 resimden 1. Nook HD+ Motherboard Replacement: adım 2, 3 resimden 2. Nook HD+ Motherboard Replacement: adım 2, 3 resimden 3.
      • Remove twenty 5.0 mm Torx T5 screws that hold the chassis to the back casing using a screwdriver.
      • Disconnect battery from motherboard.
      • Remove back casing.
      FixBot'a Sor
      Yorum Ekle
    3. Nook HD+ Motherboard Replacement: adım 3, 2 resimden 1. Nook HD+ Motherboard Replacement: adım 3, 2 resimden 2.
      Bu adımda kullanılan alet:
      • Disconnect both ribbons from the motherboard by pulling up on the dark grey flaps and pulling out the ribbons.
      • Use tweezers to lift the flaps.
      FixBot'a Sor
      Yorum Ekle
    4. Nook HD+ Motherboard Replacement: adım 4, 1 resimden 1.
      • Disconnect the small red and black ribbon connected to the speaker from the white clip on the motherboard.
      • No tool is needed. Gently pull on the wires until the piece disconnects.
      FixBot'a Sor
      Yorum Ekle
    5. Nook HD+ Motherboard Replacement: adım 5, 1 resimden 1.
      • Disconnect antenna from motherboard by pulling up with slight force.
      FixBot'a Sor
      Yorum Ekle
    6. Nook HD+ Motherboard Replacement: adım 6, 2 resimden 1. Nook HD+ Motherboard Replacement: adım 6, 2 resimden 2.
      • Remove two 5.0 mm Torx T5 screws attached to the motherboard using a screwdriver.
      • Lift the small foam piece attached to the black strip on the motherboard and gently pull up.
      FixBot'a Sor
      Yorum Ekle
    7. Nook HD+ Motherboard Replacement: adım 7, 2 resimden 1. Nook HD+ Motherboard Replacement: adım 7, 2 resimden 2.
      • With the black strip lifted, carefully snap the motherboard out of the plastic pieces holding it down.
      • Remove the motherboard.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Brennan Holcombe
256 İtibar
2 adet Kılavuz yazıldı
Ekip
IUPUI, Team 3-3, Harley Spring 2022 IUPUI, Team 3-3, Harley Spring 2022 üyesi
IUPUI-HARLEY-S22S3G3
3 Üyeler
3 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 18
Her zaman: 504
