Ana içeriğe geç
Nook HD+ Speaker Replacement
Neye ihtiyacın var
  1. Nook HD+ Speaker Replacement, Take off the Top Frame: adım 1, 1 resimden 1.
    • Wedge the plastic opening piece underneath the bottom left hand corner of the front frame
    • Pry open the front frame.
  2. Nook HD+ Speaker Replacement, Remove the screws: adım 2, 2 resimden 1. Nook HD+ Speaker Replacement, Remove the screws: adım 2, 2 resimden 2.
    • Remove every visible screw tying the chassis to the bottom frame using a T-4 screwdriver bit.
  3. Nook HD+ Speaker Replacement, Remove the Battery: adım 3, 2 resimden 1. Nook HD+ Speaker Replacement, Remove the Battery: adım 3, 2 resimden 2.
    • Carefully remove the bottom frame from center chassis.
    • Detach the battery ribbon from the motherboard.
    • Flip the center chaise onto the screen side with the hole positioned on the bottom right hand corner.
  4. Nook HD+ Speaker Replacement, Unscrew the speaker: adım 4, 1 resimden 1.
    • In the bottom left hand corner remove the 3 screws that at attached to the speaker
    • Disconnect the small red and black ribbon connected to the speaker from the white clip on the mother board.
    • Replace old speaker with new speaker then follow instructions in reverse order to reassemble
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Alex Pelicas
283 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 2-3, Duarte Fall 2014 UMass Dartmouth, Team 2-3, Duarte Fall 2014 üyesi
UMASSD-DUARTE-F14S2G3
5 Üyeler
10 adet Kılavuz yazıldı
Bir Yorum
After purchasing a replacement speaker, these steps worked well. Process to a fairly relaxed 20 minutes.
The only thing I’d add is that the speaker is part # AAC121217U22A, and appears to be a bespoke part containing two speakers.
Knowing what part to look for may help others looking for a replacement part.
Jamal Taylor - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 8
Her zaman: 749
