Ana içeriğe geç
Nook HD+ Top Frame Replacement
Neye ihtiyacın var
  1. Nook HD+ Top Frame Replacement, Removing Top Frame: adım 1, 3 resimden 1. Nook HD+ Top Frame Replacement, Removing Top Frame: adım 1, 3 resimden 2. Nook HD+ Top Frame Replacement, Removing Top Frame: adım 1, 3 resimden 3.
    • Wedge the plastic opening tool underneath the frame at the bottom left hand corner of the Nook HD+ and begin prying open the front frame.
    • Note there will be glue and be careful not to break the clips.
    FixBot'a Sor
    Yorum Ekle
  2. Nook HD+ Top Frame Replacement, Add New Glue: adım 2, 1 resimden 1.
    • Apply glue round the inside perimeter of the new frame on the clip side.
    FixBot'a Sor
    Yorum Ekle
  3. Nook HD+ Top Frame Replacement: adım 3, 1 resimden 1.
    • Line up the new frame with the bottom left hand edge of the frame lined up with the hole on the center chaise push down on the frame until all the clips pop back into the slot the belong.
    • Run finger around the entire frame making sure all the clips are in place.
    • Let glue dry.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Alex Pelicas
283 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 2-3, Duarte Fall 2014 UMass Dartmouth, Team 2-3, Duarte Fall 2014 üyesi
UMASSD-DUARTE-F14S2G3
5 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 18
Her zaman: 1,065
