Ana içeriğe geç
Nook HD+ Volume/Power Buttons Replacement
Neye ihtiyacın var
  1. Nook HD+ Volume/Power Buttons Replacement, Volume/Power Buttons: adım 1, 3 resimden 1. Nook HD+ Volume/Power Buttons Replacement, Volume/Power Buttons: adım 1, 3 resimden 2. Nook HD+ Volume/Power Buttons Replacement, Volume/Power Buttons: adım 1, 3 resimden 3.
    • Open the plastic frame by wedging the plastic iFixit opening tool under the plastic frame to remove adhesive.
    • Pop up all plastic tabs that secure the frame to the chassis.
    FixBot'a Sor
    Yorum Ekle
  2. Nook HD+ Volume/Power Buttons Replacement: adım 2, 3 resimden 1. Nook HD+ Volume/Power Buttons Replacement: adım 2, 3 resimden 2. Nook HD+ Volume/Power Buttons Replacement: adım 2, 3 resimden 3.
    • Remove twenty 5.0 mm Torx T5 screws that hold the chassis to the back casing.
    • Disconnect battery from motherboard.
    • Remove back casing.
    FixBot'a Sor
    Yorum Ekle
  3. Nook HD+ Volume/Power Buttons Replacement: adım 3, 2 resimden 1. Nook HD+ Volume/Power Buttons Replacement: adım 3, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Disconnect both ribbons from the motherboard by pulling up on the dark grey flaps and pulling out the ribbons.
    • Use tweezers to lift the flaps.
    FixBot'a Sor
    Yorum Ekle
  4. Nook HD+ Volume/Power Buttons Replacement: adım 4, 2 resimden 1. Nook HD+ Volume/Power Buttons Replacement: adım 4, 2 resimden 2.
    • Remove three 5.0 mm Torx T5 screws that secure buttons to chassis.
    • Slide button assembly up and out of the chassis.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Brennan Holcombe
256 İtibar
2 adet Kılavuz yazıldı
Ekip
IUPUI, Team 3-3, Harley Spring 2022 IUPUI, Team 3-3, Harley Spring 2022 üyesi
IUPUI-HARLEY-S22S3G3
3 Üyeler
3 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 20
Her zaman: 366
