Ana içeriğe geç
Nook HD Button Replacement
Neye ihtiyacın var
  1. Nook HD Button Replacement, Case: adım 1, 3 resimden 1. Nook HD Button Replacement, Case: adım 1, 3 resimden 2. Nook HD Button Replacement, Case: adım 1, 3 resimden 3.
    • Be sure the device is powered off. Clean the device to prevent any dirt and dust from entering into the device.
    • Use the plastic opening tool to gently pry the plastic screen frame away from the screen. Run the plastic opening tool along the interior edge of the screen until the screen frame is completely separated from the glass.
    • The screen frame is held onto the Nook by a set of tab that run around the outside of the frame. There may also be a line of rubber cement around the Nook under the screen frame. If your Nook has this, you will have to dig deep to separate the frame from the Nook.
    FixBot'a Sor
    Yorum Ekle
  2. Nook HD Button Replacement: adım 2, 2 resimden 1. Nook HD Button Replacement: adım 2, 2 resimden 2.
    • Use a T5 screwdriver to remove the seventeen 5.0 millimeter screws from the back casing.
    FixBot'a Sor
    Yorum Ekle
  3. Nook HD Button Replacement: adım 3, 3 resimden 1. Nook HD Button Replacement: adım 3, 3 resimden 2. Nook HD Button Replacement: adım 3, 3 resimden 3.
    • Slowly pull the back casing away from the screen and motherboard.
    • There is a cable attaching the battery in the back plate to the motherboard. Avoid detaching either end of the cable during this step.
    FixBot'a Sor
    Yorum Ekle
  4. Nook HD Button Replacement: adım 4, 3 resimden 1. Nook HD Button Replacement: adım 4, 3 resimden 2. Nook HD Button Replacement: adım 4, 3 resimden 3.
    • Use the plastic opening tool to gently unclip the wire from the pins by pulling the white connector up.
    FixBot'a Sor
    Yorum Ekle
  5. Nook HD Button Replacement, Motherboard: adım 5, 2 resimden 1. Nook HD Button Replacement, Motherboard: adım 5, 2 resimden 2.
    • There are three ribbon cable connections that you must disconnect in order to remove the motherboard.
    • The first of these connections is small black - grey plastic connection housing.
    • Use the plastic opening tool to pull the black part of the ribbon cable housing up and away from the circuit board.
    • Carefully pull the ribbon cable out of the plastic connection housing.
    FixBot'a Sor
    Yorum Ekle
  6. Nook HD Button Replacement: adım 6, 1 resimden 1.
    • The second of these connections is a small white - tan plastic connection housing.
    • Use the plastic opening tool to pull the tan part of the housing up and away from the circuit board.
    FixBot'a Sor
    Yorum Ekle
  7. Nook HD Button Replacement: adım 7, 1 resimden 1.
    • The final connection is a large orange ribbon cable that connects to an entirely separate circuit board.
    • Use the plastic opening tool to gently pry the cable away from the smaller circuit board as to disconnect the cable from the pins.
    FixBot'a Sor
    Yorum Ekle
  8. Nook HD Button Replacement: adım 8, 1 resimden 1.
    • Use the T5 torx screwdriver to remove the four 2.5 millimeter screws that attach the motherboard to the back plate.
    FixBot'a Sor
    Yorum Ekle
  9. Nook HD Button Replacement: adım 9, 1 resimden 1.
    • Gently pull the motherboard straight off of the back plate.
    FixBot'a Sor
    Yorum Ekle
  10. Nook HD Button Replacement, Button: adım 10, 2 resimden 1. Nook HD Button Replacement, Button: adım 10, 2 resimden 2.
    • Using the plastic opening tool, lever the button arms towards the center of the nook so the button mechanism slides free.
    • Check moving parts for dust or other obstructions and contacts for insulators.
    FixBot'a Sor
    Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Julian Lohser
101 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 3-43, Maness Spring 2014 Cal Poly, Team 3-43, Maness Spring 2014 üyesi
CPSU-MANESS-S14S3G43
5 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 16
Her zaman: 1,874
