Ana içeriğe geç
Nook Tablet Back Cover Replacement
Neye ihtiyacın var
  1. Nook Tablet Back Cover Replacement, Back Cover: adım 1, 1 resimden 1.
    • Flip the Nook over.
    FixBot'a Sor
    Yorum Ekle
  2. Nook Tablet Back Cover Replacement: adım 2, 2 resimden 1. Nook Tablet Back Cover Replacement: adım 2, 2 resimden 2.
    • Lift the flap that reads "Nook" to reveal the tape that is underneath. Remove the memory card if one is present.
    • Remove the tape covering the round holes to reveal two T5 Torx screws.
    • Remove the two T5 Torx screws securing the back cover.
    FixBot'a Sor
    Yorum Ekle
  3. Nook Tablet Back Cover Replacement: adım 3, 2 resimden 1. Nook Tablet Back Cover Replacement: adım 3, 2 resimden 2.
    • Insert the flat end of a spudger between the front panel and the rear assembly.
    • Though these photos show a screwdriver, use a spudger or plastic opening tool in order to prevent damage to the device.
    • Use a spudger to lift the the back panel from the rest of the Nook.
    FixBot'a Sor
    Yorum Ekle
  4. Nook Tablet Back Cover Replacement: adım 4, 2 resimden 1. Nook Tablet Back Cover Replacement: adım 4, 2 resimden 2.
    • Slide the spudger around the edges of the Nook to loosen the back panel.
    FixBot'a Sor
    Yorum Ekle
  5. Nook Tablet Back Cover Replacement: adım 5, 1 resimden 1.
    • Pull the back panel off the Nook.
    FixBot'a Sor
    Yorum Ekle
Sonuç
To reassemble your device, line up the piece that was removed with how it was on before and then just firmly press down till it snaps into place.
5 farklı kişi bu kılavuzu tamamladı.
Jacob Metzinger
89 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 1-4, Propen Fall 2012 Cal Poly, Team 1-4, Propen Fall 2012 üyesi
CPSU-PROPEN-F12S1G4
4 Üyeler
14 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 11
Son 30 gün: 42
Her zaman: 6,512
