Ana içeriğe geç
Nook Tablet Midframe Replacement
Neye ihtiyacın var
    1. Nook Tablet Midframe Replacement, Back Cover: adım 1, 1 resimden 1.
      • Flip the Nook over.
      FixBot'a Sor
      Yorum Ekle
    2. Nook Tablet Midframe Replacement: adım 2, 2 resimden 1. Nook Tablet Midframe Replacement: adım 2, 2 resimden 2.
      • Lift the flap that reads "Nook" to reveal the tape that is underneath. Remove the memory card if one is present.
      • Remove the tape covering the round holes to reveal two T5 Torx screws.
      • Remove the two T5 Torx screws securing the back cover.
      FixBot'a Sor
      Yorum Ekle
    3. Nook Tablet Midframe Replacement: adım 3, 2 resimden 1. Nook Tablet Midframe Replacement: adım 3, 2 resimden 2.
      • Insert the flat end of a spudger between the front panel and the rear assembly.
      • Though these photos show a screwdriver, use a spudger or plastic opening tool in order to prevent damage to the device.
      • Use a spudger to lift the the back panel from the rest of the Nook.
      FixBot'a Sor
      Yorum Ekle
    4. Nook Tablet Midframe Replacement: adım 4, 2 resimden 1. Nook Tablet Midframe Replacement: adım 4, 2 resimden 2.
      • Slide the spudger around the edges of the Nook to loosen the back panel.
      FixBot'a Sor
      Yorum Ekle
    5. Nook Tablet Midframe Replacement: adım 5, 1 resimden 1.
      • Pull the back panel off the Nook.
      FixBot'a Sor
      Yorum Ekle
    1. Nook Tablet Midframe Replacement, Screen Bezel: adım 6, 2 resimden 1. Nook Tablet Midframe Replacement, Screen Bezel: adım 6, 2 resimden 2.
      • Using the T5 Torx screwdriver, remove the ten T5 screws from around the edges of the silver midframe.
      FixBot'a Sor
      Yorum Ekle
    2. Nook Tablet Midframe Replacement: adım 7, 2 resimden 1. Nook Tablet Midframe Replacement: adım 7, 2 resimden 2.
      • Using a spudger or plastic opening tool, carefully pry the screen bezel away from the silver midframe.
      FixBot'a Sor
      Yorum Ekle
    1. Nook Tablet Midframe Replacement, Disconnect the Battery: adım 8, 2 resimden 1. Nook Tablet Midframe Replacement, Disconnect the Battery: adım 8, 2 resimden 2.
      • Lift up the foam pad at the corner of the battery to reveal the battery connector.
      • Use a spudger or plastic opening tool to disconnect the battery cable from the motherboard.
      • These photos show a screwdriver, but we recommend using a nonconductive tool like a spudger to prevent a potential short.
      FixBot'a Sor
      Yorum Ekle
    1. Nook Tablet Midframe Replacement, Midframe: adım 9, 1 resimden 1.
      • Lift up the foam that covers the power connector and volume connector.
      • Disconnect the power and volume cables from their sockets on the motherboard.
      FixBot'a Sor
      Yorum Ekle
    2. Nook Tablet Midframe Replacement: adım 10, 2 resimden 1. Nook Tablet Midframe Replacement: adım 10, 2 resimden 2.
      • Carefully lift the silver midframe away from the motherboard and display assembly.
      • Be careful when handling the motherboard, making sure to not dislodge/shift any of its major components.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Holly Lowe
238 İtibar
3 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 19
Her zaman: 759
