Ana içeriğe geç
Nortel Networks i2004 IP Back Cover Replacement
Neye ihtiyacın var
  1. Nortel Networks i2004 IP Back Cover Replacement, Back Cover: adım 1, 3 resimden 1. Nortel Networks i2004 IP Back Cover Replacement, Back Cover: adım 1, 3 resimden 2. Nortel Networks i2004 IP Back Cover Replacement, Back Cover: adım 1, 3 resimden 3.
    • Flip the phone over to view the back.
    • Remove the power and phone cords.
  2. Nortel Networks i2004 IP Back Cover Replacement: adım 2, 1 resimden 1.
    • Remove the seven 8mm Phillips #2 screws.
  3. Nortel Networks i2004 IP Back Cover Replacement: adım 3, 2 resimden 1. Nortel Networks i2004 IP Back Cover Replacement: adım 3, 2 resimden 2.
    • Lift up the back cover slowly because there are still wires attached to the circuit board.
    • Lifting the back cover should not require a lot of force; simply lift with your fingertips.
  4. Nortel Networks i2004 IP Back Cover Replacement: adım 4, 1 resimden 1.
    • Disconnect the rubber piece by pulling it out of the slot, freeing the back cover completely.
  5. Nortel Networks i2004 IP Back Cover Replacement: adım 5, 2 resimden 1. Nortel Networks i2004 IP Back Cover Replacement: adım 5, 2 resimden 2.
    • Remove the six 8mm Phillips #2 screws.
    • Pull the speaker phone cover straight up.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Elizabeth
160 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 10-35, Amido Winter 2012 Cal Poly, Team 10-35, Amido Winter 2012 üyesi
CPSU-AMIDO-W12S10G35
4 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 1,202
