Ana içeriğe geç
Nortel Networks i2004 IP Buttons Replacement
Neye ihtiyacın var
  1. Nortel Networks i2004 IP Buttons Replacement, Back Cover: adım 1, 3 resimden 1. Nortel Networks i2004 IP Buttons Replacement, Back Cover: adım 1, 3 resimden 2. Nortel Networks i2004 IP Buttons Replacement, Back Cover: adım 1, 3 resimden 3.
    • Flip the phone over to view the back.
    • Remove the power and phone cords.
    FixBot'a Sor
    Yorum Ekle
  2. Nortel Networks i2004 IP Buttons Replacement: adım 2, 1 resimden 1.
    • Remove the seven 8mm Phillips #2 screws.
    FixBot'a Sor
    Yorum Ekle
  3. Nortel Networks i2004 IP Buttons Replacement: adım 3, 2 resimden 1. Nortel Networks i2004 IP Buttons Replacement: adım 3, 2 resimden 2.
    • Lift up the back cover slowly because there are still wires attached to the circuit board.
    • Lifting the back cover should not require a lot of force; simply lift with your fingertips.
    FixBot'a Sor
    Yorum Ekle
  4. Nortel Networks i2004 IP Buttons Replacement: adım 4, 1 resimden 1.
    • Disconnect the rubber piece by pulling it out of the slot, freeing the back cover completely.
    FixBot'a Sor
    Yorum Ekle
  5. Nortel Networks i2004 IP Buttons Replacement: adım 5, 2 resimden 1. Nortel Networks i2004 IP Buttons Replacement: adım 5, 2 resimden 2.
    • Remove the six 8mm Phillips #2 screws.
    • Pull the speaker phone cover straight up.
    FixBot'a Sor
    Yorum Ekle
  6. Nortel Networks i2004 IP Buttons Replacement, Circuit Board: adım 6, 1 resimden 1.
    • Remove the red and white wires from the rubber casing rim.
    FixBot'a Sor
    Yorum Ekle
  7. Nortel Networks i2004 IP Buttons Replacement: adım 7, 2 resimden 1. Nortel Networks i2004 IP Buttons Replacement: adım 7, 2 resimden 2.
    • Lift out the speaker and set it away from the tray that holds it.
    • Then remove the black plastic tray at the bottom by lifting it straight up.
    FixBot'a Sor
    Yorum Ekle
  8. Nortel Networks i2004 IP Buttons Replacement: adım 8, 1 resimden 1.
    • Remove the two 8mm Phillips #2 screws.
    FixBot'a Sor
    Yorum Ekle
  9. Nortel Networks i2004 IP Buttons Replacement: adım 9, 2 resimden 1. Nortel Networks i2004 IP Buttons Replacement: adım 9, 2 resimden 2.
    • Pull the gray plastic casing away from the circuit board as you remove the clear, curved, plastic piece straight up.
    FixBot'a Sor
    Yorum Ekle
  10. Nortel Networks i2004 IP Buttons Replacement: adım 10, 3 resimden 1. Nortel Networks i2004 IP Buttons Replacement: adım 10, 3 resimden 2. Nortel Networks i2004 IP Buttons Replacement: adım 10, 3 resimden 3.
    • There are three clips on the circuit board to un-clip.
    • Unclip both back black clips with your fingertips.
    • Push the middle black clip towards the bottom of the picture with a flathead screwdriver.
    FixBot'a Sor
    Yorum Ekle
  11. Nortel Networks i2004 IP Buttons Replacement: adım 11, 2 resimden 1. Nortel Networks i2004 IP Buttons Replacement: adım 11, 2 resimden 2.
    • There's a brown ribbon still attached to the circuit board and phone case, so don't pull the circuit board completely off just yet.
    • Lift the edge of the circuit board over the phone case and slightly up, so the bottom of circuit board can be viewed.
    FixBot'a Sor
    Yorum Ekle
  12. Nortel Networks i2004 IP Buttons Replacement: adım 12, 1 resimden 1.
    • Push down each brown clip on either side of the brown metal strip using your fingertip.
    • Detach the circuit board from the brown ribbon.
    FixBot'a Sor
    Yorum Ekle
  13. Nortel Networks i2004 IP Buttons Replacement: adım 13, 1 resimden 1.
    • Remove the clear rubber casing.
    • Be careful not to flip over the front phone casing or all of the buttons will fall out.
    FixBot'a Sor
    Yorum Ekle
  14. Nortel Networks i2004 IP Buttons Replacement, Buttons: adım 14, 1 resimden 1.
    • Press the broken button from the front of the phone.
    • Remove the broken button through the back.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Andrew Wang
9 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 10-35, Amido Winter 2012 Cal Poly, Team 10-35, Amido Winter 2012 üyesi
CPSU-AMIDO-W12S10G35
4 Üyeler
20 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 12
Son 30 gün: 28
Her zaman: 1,327
