Ana içeriğe geç
Nostalgia Electrics PCM805 Heating Element
Neye ihtiyacın var
    1. Nostalgia Electrics PCM805 Heating Element, Bowl: adım 1, 1 resimden 1.
      • Make sure that the device is unplugged and has not been used recently because the extractor head and bowl can be very hot.
      • Place the device on a steady table.
      • Lift and remove the rim.
      FixBot'a Sor
      Yorum Ekle
    2. Nostalgia Electrics PCM805 Heating Element: adım 2, 3 resimden 1. Nostalgia Electrics PCM805 Heating Element: adım 2, 3 resimden 2. Nostalgia Electrics PCM805 Heating Element: adım 2, 3 resimden 3.
      • Twist the bowl clockwise until it is free of the groove and lift to remove.
      FixBot'a Sor
      Yorum Ekle
    3. Nostalgia Electrics PCM805 Heating Element, Extractor Head: adım 3, 2 resimden 1. Nostalgia Electrics PCM805 Heating Element, Extractor Head: adım 3, 2 resimden 2.
      • Firmly grip the extractor head and slowly lift vertically to remove from the device.
      FixBot'a Sor
      Yorum Ekle
    1. Nostalgia Electrics PCM805 Heating Element, Unscrewing the base: adım 4, 2 resimden 1. Nostalgia Electrics PCM805 Heating Element, Unscrewing the base: adım 4, 2 resimden 2.
      • Unplug the device before following this guide.
      • First, place the device on its side, making sure the switch is not facing down.
      • Remove the eight 12mm Phillips #02 screws from the base.
      FixBot'a Sor
      Yorum Ekle
    2. Nostalgia Electrics PCM805 Heating Element: adım 5, 1 resimden 1.
      • Gently separate the panel from the device.
      • Be sure not to tug at the wires that are still connected.
      FixBot'a Sor
      Yorum Ekle
    1. Nostalgia Electrics PCM805 Heating Element, Nostalgia Electrics PCM805 Wiring Teardown: adım 6, 2 resimden 1. Nostalgia Electrics PCM805 Heating Element, Nostalgia Electrics PCM805 Wiring Teardown: adım 6, 2 resimden 2.
      • Locate the tie strap holding the wires and cut with a pair of scissors.
      • Use care not to snip the wires.
      FixBot'a Sor
      Yorum Ekle
    2. Nostalgia Electrics PCM805 Heating Element: adım 7, 3 resimden 1. Nostalgia Electrics PCM805 Heating Element: adım 7, 3 resimden 2. Nostalgia Electrics PCM805 Heating Element: adım 7, 3 resimden 3.
      • Make note of the wiring arrangement of each bundle before this step.
      • Using wire cutters, cut each wire as close to the wire connector as possible.
      • Cut the wires in both bundles.
      • To reassemble the cotton candy maker after cutting the wires, follow our rewiring guide.
      FixBot'a Sor
      Yorum Ekle
    1. Nostalgia Electrics PCM805 Heating Element, Heating Element: adım 8, 2 resimden 1. Nostalgia Electrics PCM805 Heating Element, Heating Element: adım 8, 2 resimden 2.
      • Remove the six 10mm Phillips #02 screws that secure the metal housing covering the heating element.
      • Remove the metal housing.
      FixBot'a Sor
      Yorum Ekle
    2. Nostalgia Electrics PCM805 Heating Element: adım 9, 2 resimden 1. Nostalgia Electrics PCM805 Heating Element: adım 9, 2 resimden 2.
      • Remove the four 9mm Phillips #02 screws that secure the heating element to the rest of the device.
      FixBot'a Sor
      Yorum Ekle
    3. Nostalgia Electrics PCM805 Heating Element: adım 10, 2 resimden 1. Nostalgia Electrics PCM805 Heating Element: adım 10, 2 resimden 2.
      • Line up the prongs on the motor shaft with the slots in either side of the hole in the heating element and lift it off the device.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Nicholas Fazio
194 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team 3-5, Hickman Winter 2015 USF Tampa, Team 3-5, Hickman Winter 2015 üyesi
USFT-HICKMAN-W15S3G5
5 Üyeler
16 adet Kılavuz yazıldı
2Kılavuz Yorumları
Where can I buy a replacement heating element?
Eric P. Rose - Yanıt Paylaş
For the heating element, the grate popped off. What silicone is used to keep the parts together? Same for the springs inside the white tubes.
Jenilee Brown - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 16
Son 30 gün: 50
Her zaman: 6,246
