Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Mağaza
Giriş
Use this guide to replace the motor in the cotton candy maker if it has gone bad.
  1. Unplug the device before following this guide. First, place the device on its side, making sure the switch is not facing down.
    • Unplug the device before following this guide.
    • First, place the device on its side, making sure the switch is not facing down.
    • Remove the eight 12mm Phillips #02 screws from the base.
  2. Gently separate the panel from the device.
    • Gently separate the panel from the device.
    • Be sure not to tug at the wires that are still connected.
  3. Locate the tie strap holding the wires and cut with a pair of scissors. Use care not to snip the wires.
    • Locate the tie strap holding the wires and cut with a pair of scissors.
    • Use care not to snip the wires.
  4. Make note of the wiring arrangement of each bundle before this step. Using wire cutters, cut each wire as close to the wire connector as possible. Cut the wires in both bundles.
    • Make note of the wiring arrangement of each bundle before this step.
    • Using wire cutters, cut each wire as close to the wire connector as possible.
    • Cut the wires in both bundles.
    • To reassemble the cotton candy maker after cutting the wires, follow our rewiring guide.
  5. Remove the four 12mm Phillips #02 screws to free the motor housing. Remove the four 12mm Phillips #02 screws to free the motor housing.
    • Remove the four 12mm Phillips #02 screws to free the motor housing.
  6. Line up the prongs on the motor shaft with the holes in the heating element and pull the motor out. Line up the prongs on the motor shaft with the holes in the heating element and pull the motor out.
    • Line up the prongs on the motor shaft with the holes in the heating element and pull the motor out.
Sonuç
Joshua Harriger
309 İtibar
2 adet Kılavuz yazıldı
Takım
USF Tampa, Team 3-5, Hickman Winter 2015 USF Tampa, Team 3-5, Hickman Winter 2015 üyesi
USFT-HICKMAN-W15S3G5
5 Üyeler
8 adet Kılavuz yazıldı
2 Yorum
Hello.
I purchased this item in a red variation from VAT19. It does not work but the light comes on. I live in the UK and we have a higher Voltage(240V) running in our domestic supply.
Something may have blown.
Can you advise what is it likely to be?
If there is a part that we can replace, can you advise which one and where I can purchase it from please?
Moh - Yanıt
Hi, I need the cotton machine from the nostalgia cotton sugar machine and I don't know where to get it. can you help me? My email is terebcn18@hotmail.com
Teresa gb - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 19
Her zaman: 2,261
