Ana içeriğe geç
Nostalgia Electrics PCM805 Power Switch Replacement
Neye ihtiyacın var
  1. Nostalgia Electrics PCM805 Power Switch Replacement, Unscrewing the base: adım 1, 2 resimden 1. Nostalgia Electrics PCM805 Power Switch Replacement, Unscrewing the base: adım 1, 2 resimden 2.
    • Unplug the device before following this guide.
    • First, place the device on its side, making sure the switch is not facing down.
    • Remove the eight 12mm Phillips #02 screws from the base.
  2. Nostalgia Electrics PCM805 Power Switch Replacement: adım 2, 1 resimden 1.
    • Gently separate the panel from the device.
    • Be sure not to tug at the wires that are still connected.
  3. Nostalgia Electrics PCM805 Power Switch Replacement, Power Switch: adım 3, 1 resimden 1.
    • Locate the switch/wire assembly inside the device.
  4. Nostalgia Electrics PCM805 Power Switch Replacement: adım 4, 1 resimden 1.
    • Pull back the insulation sleeves to expose the connector heads.
  5. Nostalgia Electrics PCM805 Power Switch Replacement: adım 5, 2 resimden 1. Nostalgia Electrics PCM805 Power Switch Replacement: adım 5, 2 resimden 2.
    • Note the color of each wire and the order you remove them.
    • Using a pair of pliers, firmly grip the base of the wire.
    • Be sure to grip where the connector meets the wire and not where the connector covers the switch prong.
    • Pull the wire straight out of the switch.
    • Repeat this step for each wire.
  6. Nostalgia Electrics PCM805 Power Switch Replacement: adım 6, 2 resimden 1. Nostalgia Electrics PCM805 Power Switch Replacement: adım 6, 2 resimden 2.
    • Using pliers, pinch tabs at the top and bottom of switch.
    • While pinching the tabs, push the switch until the tabs are on the outside of the device.
  7. Nostalgia Electrics PCM805 Power Switch Replacement: adım 7, 2 resimden 1. Nostalgia Electrics PCM805 Power Switch Replacement: adım 7, 2 resimden 2.
    • Remove the switch from the device.
Sonuç
Carlton
672 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 3-5, Hickman Winter 2015 USF Tampa, Team 3-5, Hickman Winter 2015 üyesi
USFT-HICKMAN-W15S3G5
5 Üyeler
8 adet Kılavuz yazıldı
Bir Yorum
The red light turns on but the disk isnt spinning or heating up and when the out let has power
Manuela Velez - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 7
Her zaman: 1,940
