Ana içeriğe geç
Nostalgia Electrics RHP-310 Power Switch Replacement
Neye ihtiyacın var
  1. Nostalgia Electrics RHP-310 Power Switch Replacement, Power Switch: adım 1, 1 resimden 1.
    • Unplug the popper.
    • Lift the lid up to remove it.
  2. Nostalgia Electrics RHP-310 Power Switch Replacement: adım 2, 1 resimden 1.
    • Lay the popper on its side.
    • Remove the five 12mm Philips #2 screws around the perimeter of the base with the Phillips #2 screwdriver.
    • Remove the two 15mm Philips #2 screws in the center of the base with the Phillips #2 screwdriver.
    • Put the removed screws in a safe place, they will be needed later to reattach the housing to the base.
  3. Nostalgia Electrics RHP-310 Power Switch Replacement: adım 3, 1 resimden 1.
    • Flip the base over to view the interior of the base panel.
    • Unscrew the two 10 mm Philips #2 screws from the base panel.
    • Remove the base and set it aside.
  4. Nostalgia Electrics RHP-310 Power Switch Replacement: adım 4, 2 resimden 1. Nostalgia Electrics RHP-310 Power Switch Replacement: adım 4, 2 resimden 2.
    • Locate the power switch connected to the side of the housing.
    • Pinch the sides of the power switch.
    • Push the power button up and out of the housing.
  5. Nostalgia Electrics RHP-310 Power Switch Replacement: adım 5, 1 resimden 1.
    • Remove the wires connected to the power switch that should be detached from the housing.
    • Gently pry the wires loose from the power switch with the plastic opening tool.
    • The wires should easily pop out from the power switch.
  6. Nostalgia Electrics RHP-310 Power Switch Replacement: adım 6, 1 resimden 1.
    • Remove the power switch from the housing unit.
    • You can now replace the power switch, if necessary.
Sonuç
Dana Clarke
50 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 16-57, Forte Fall 2012 Cal Poly, Team 16-57, Forte Fall 2012 üyesi
CPSU-FORTE-F12S16G57
5 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 12
Her zaman: 1,046
