Ana içeriğe geç
Nostalgia Electrics RHP-310 Wiring Repair
Neye ihtiyacın var
  1. Nostalgia Electrics RHP-310 Wiring Repair, Power Switch: adım 1, 1 resimden 1.
    • Unplug the popper.
    • Lift the lid up to remove it.
  2. Nostalgia Electrics RHP-310 Wiring Repair: adım 2, 1 resimden 1.
    • Lay the popper on its side.
    • Remove the five 12mm Philips #2 screws around the perimeter of the base with the Phillips #2 screwdriver.
    • Remove the two 15mm Philips #2 screws in the center of the base with the Phillips #2 screwdriver.
    • Put the removed screws in a safe place, they will be needed later to reattach the housing to the base.
  3. Nostalgia Electrics RHP-310 Wiring Repair: adım 3, 1 resimden 1.
    • Flip the base over to view the interior of the base panel.
    • Unscrew the two 10 mm Philips #2 screws from the base panel.
    • Remove the base and set it aside.
  4. Nostalgia Electrics RHP-310 Wiring Repair: adım 4, 2 resimden 1. Nostalgia Electrics RHP-310 Wiring Repair: adım 4, 2 resimden 2.
    • Locate the power switch connected to the side of the housing.
    • Pinch the sides of the power switch.
    • Push the power button up and out of the housing.
  5. Nostalgia Electrics RHP-310 Wiring Repair: adım 5, 1 resimden 1.
    • Remove the wires connected to the power switch that should be detached from the housing.
    • Gently pry the wires loose from the power switch with the plastic opening tool.
    • The wires should easily pop out from the power switch.
  6. Nostalgia Electrics RHP-310 Wiring Repair: adım 6, 1 resimden 1.
    • Remove the power switch from the housing unit.
    • You can now replace the power switch, if necessary.
  7. Nostalgia Electrics RHP-310 Wiring Repair, Replacing Housing: adım 7, 2 resimden 1. Nostalgia Electrics RHP-310 Wiring Repair, Replacing Housing: adım 7, 2 resimden 2.
    • Gently remove the heating component from the popper.
    • Unscrew the four screws (11mm Philips #2 screws) that connect the white top to the housing.
    • Save the screws from this step. You will need them to connect the new housing to the white top.
  8. Nostalgia Electrics RHP-310 Wiring Repair: adım 8, 1 resimden 1.
    • Remove the white top from the housing.
  9. Nostalgia Electrics RHP-310 Wiring Repair, Replacing Fan: adım 9, 1 resimden 1.
    • Unscrew the three 10 mm Philips #2 screws that hold the heating component together.
    • Keep the screws in a safe place. You will need them to put the heating component back together.
  10. Nostalgia Electrics RHP-310 Wiring Repair: adım 10, 1 resimden 1.
    • Pull the heating component apart.
  11. Nostalgia Electrics RHP-310 Wiring Repair: adım 11, 2 resimden 1. Nostalgia Electrics RHP-310 Wiring Repair: adım 11, 2 resimden 2.
    • Locate the fan.
    • Pull the fan off the motor.
    • Do not pull too hard or you will break the motor.
  12. Nostalgia Electrics RHP-310 Wiring Repair: adım 12, 1 resimden 1.
    • You can now replace the fan. If there is debris, clean it out.
  13. Nostalgia Electrics RHP-310 Wiring Repair, Nostalgia Electrics RHP-310 Wiring Repair: adım 13, 1 resimden 1.
    • Take the heating coil out of complete heating component.
  14. Nostalgia Electrics RHP-310 Wiring Repair: adım 14, 1 resimden 1.
    • Visually check the wires for frayed wires.
    • Make sure that the wires are completely connected to a port.
  15. Nostalgia Electrics RHP-310 Wiring Repair: adım 15, 1 resimden 1.
    • If you see a wire that is not connected, solder it back into place.
    • These websites might be helpful in soldering: Wikipedia Theoatc
    • Also, use a digital multi-meter to check to make sure there is a current through the wire. If the meter does not read, you might need to replace all the wires.
    • This website may be helpful in with wiring: How Stuff Works
  16. Nostalgia Electrics RHP-310 Wiring Repair: adım 16, 1 resimden 1.
    • This website will help with reconnecting wires:eHow
Sonuç
Dana Clarke
50 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 16-57, Forte Fall 2012 Cal Poly, Team 16-57, Forte Fall 2012 üyesi
CPSU-FORTE-F12S16G57
5 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 16
Her zaman: 896
