Ana içeriğe geç
Nostalgia GCM200 Power Cable Replacement
Neye ihtiyacın var
  1. Nostalgia GCM200 Power Cable Replacement, Nostalgia GCM200 Disassembly: adım 1, 2 resimden 1. Nostalgia GCM200 Power Cable Replacement, Nostalgia GCM200 Disassembly: adım 1, 2 resimden 2.
    • Remove the two 1.3 mm Phillips #2 screws.
    • Remove the S6 spanner screw.
    • Carefully place these three screws somewhere safe to use later in reassembly.
  2. Nostalgia GCM200 Power Cable Replacement: adım 2, 1 resimden 1.
    • Split the device in half to expose the internal parts of the device.
    • Again, there are two more Phillips screws to remove.
  3. Nostalgia GCM200 Power Cable Replacement: adım 3, 1 resimden 1.
    • Remove the two screws from both sides of the heating coil.
  4. Nostalgia GCM200 Power Cable Replacement, Power Cable: adım 4, 1 resimden 1.
    • Remove (flexible) plastic sleeves from the inside end of the power cable.
    • You might want to use force, pull out while shaking it.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Praful Busa
267 İtibar
2 adet Kılavuz yazıldı
Ekip
UW Tacoma, Team S1-G4, Liner Summer 2017 UW Tacoma, Team S1-G4, Liner Summer 2017 üyesi
UWT-LINER-SU17S1G4
4 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 264
