Ana içeriğe geç
Novatel MiFi 2200 Case Replacement
Neye ihtiyacın var
  1. Novatel MiFi 2200 Case Replacement, Battery: adım 1, 1 resimden 1.
    • Remove the rear cover by pressing down on the cover and pulling it away from the device.
  2. Novatel MiFi 2200 Case Replacement: adım 2, 1 resimden 1.
    • Place your finger on the back of the battery located near the edge of the device.
    • Push your finger into the battery and lift up to pop the battery out of the device.
  3. Novatel MiFi 2200 Case Replacement, Case: adım 3, 1 resimden 1.
    • Using a metal spudger, pry open the device around the seam between the front and back cover.
    • It may be difficult to split apart, so use force with caution.
    • It may seem like you are breaking the device, but you will only be breaking the adhesive lining that keeps the device sealed.
  4. Novatel MiFi 2200 Case Replacement: adım 4, 1 resimden 1.
    • Once the seal has been broken all the way around, open the cases using your hands.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Justin Russo
196 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 7-36, Maness Spring 2012 Cal Poly, Team 7-36, Maness Spring 2012 üyesi
CPSU-MANESS-S12S7G36
5 Üyeler
5 adet Kılavuz yazıldı
Bir Yorum
If case gets damaged, is there a place to but the case
Snehraj Merchant - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 12
Her zaman: 1,541
