Giriş
Novation Launchkey mini MK3 / FLkey mini disassembly guide. I went in to fix two broken keys on an old Launchkey. In the process I compared the internals with the newer FLkey. Spoiler: There is no difference in hardware.
Neye ihtiyacın var
This manual goes for both Lauchkey mini MK3 and FLkey, as they are similar in build.
Flipping it upside down, shows 4 screws. After removing these screws, the whole thing still feels just as rigid.
Next up are the clippings. I found that starting at a corner works best for me. Then carfully with a pick or screwdriver work yourway around.
There's 4 clips on the long sides and 3 on the short sides. Be careful not to open up after undoing all clips.
When all clips are undone, and the top and bottom shells are lose, carefully lift the back a little and then slide the top shell towards the key-bed.
Carefully flip the top and undo the ribbon cable connecting the key-bed with the top shell.
The keyboard is undone by unscrewing 9 screws. The keys can then be wiggled out.
Mind that the rubber strip has a short and long feet. The short one goes to the front of the board.
CY8C4024LQ ARM Microcontroller
HC595 bit-shifter
74HC4051D 8-channel analog multiplexer/demultiplexer
74HC165D 8-bit parallel-in/serial out shift register
74HC238D - 3-to-8 line decoder/demultiplexermxic
STM32F401RB - STMicroelectronics STM32F401RB - High-performance access line, Arm Cortex-M4 core with DSP and FPU, 128 Kbytes of Flash memory, 84 MHz CPU, ART Accelerator. Yes, apperently it accelerates art :)
MXIC MX25L8006E - 3V, 8M-bit[x 1/x 2] CMOS Serial flash memory
Unscrew the four screw
Undo the ribon cable by pulling the black clamp ever so carefull.
Remove CPU board.
Unscrew 15 screws.
Remove the 8 rotary knob caps from the from of the board, by simply pulling on them. The main board can now be removed.
Removing the silicon pads as last, the midi keyboard is now fully disassembled.
I applaud Novation for making a device that is easy to open. No hidden screws and many screw indicators make this easily to repair. Just be careful with the ribbon cables.
What I don't understand is that I had to buy a complete new Novation FLKey to get features that work better with FL Studio. But looking inside, there seems to be no difference in hardware. So why not simply release a FL Studio driver? Maybe the firmware can be snarfed...
4 farklı kişi bu kılavuzu tamamladı.
