Giriş
Make sure to be very careful when handling the battery, lithium batteries are prone to exploding when bent or punctured. If the device is experiencing a short life span or any other issues regarding the battery, follow this guide to replace the battery.
Neye ihtiyacın var
Turn the device screen side down.
Carefully remove the back piece with the iFixit opening tool.
Disconnect the press-fit black and red curly wire from where it connects on the motherboard.
Pry the battery away from the display screen gently using a nylon spudger or the plastic opening tools.
