Giriş
How to replace the glass screen on the NuVision 10.1 Atom. Be careful handling the lithium battery as they are prone to exploding when bent or punctured. Also, make sure to carefully remove the glass screen. If the glass breaks, there is a chance of cutting yourself.
Neye ihtiyacın var
Turn the device screen side down.
Carefully remove the back piece with the iFixit opening tool.
Disconnect the press-fit black and red curly wire from where it connects on the motherboard.
Pry the battery away from the display screen gently using a nylon spudger or the plastic opening tools.
Remove six silver 2.8mm screws surrounding the battery using the Phillips #000 screwdriver.
Bir başkası bu kılavuzu tamamladı.
