Ana içeriğe geç
NuVision Duo 11 MicroSD Port Replacement
Neye ihtiyacın var
  1. NuVision Duo 11 MicroSD Port Replacement, Back Panel: adım 1, 1 resimden 1.
    • Place the flat end of a nylon spudger in the gap between the cover and the rest of the device.
    • Slide the spudger down each side until you hear numerous clicks.
    • Remove the back panel from the tablet.
    FixBot'a Sor
    Yorum Ekle
  2. NuVision Duo 11 MicroSD Port Replacement, MicroSD Port: adım 2, 3 resimden 1. NuVision Duo 11 MicroSD Port Replacement, MicroSD Port: adım 2, 3 resimden 2. NuVision Duo 11 MicroSD Port Replacement, MicroSD Port: adım 2, 3 resimden 3.
    • Remove the 4.8 mm screws from the MicroSD port using a JIS #000 screwdriver.
    • Unclip the male ribbon from the female ribbon port carefully.
    • Remove the MicroSD port from the tablet.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Zachary Picard
157 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 7-1, Ryckebusch Spring 2023 UMass Dartmouth, Team 7-1, Ryckebusch Spring 2023 üyesi
UMASSD-RYCKEBUSCH-S23S7G1
3 Üyeler
6 adet Kılavuz yazıldı
1Rehber Yorum
Does anyone know where the CMOS battery is located?
James Zagranis - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 24
Her zaman: 377
