Ana içeriğe geç
NuVision TM1088 Motherboard Replacement
Neye ihtiyacın var
  1. NuVision TM1088 Motherboard Replacement, Rear Cover: adım 1, 1 resimden 1.
    • Place the plastic opening tool between the front and rear cover and pry up on each corner of the cover.
  2. NuVision TM1088 Motherboard Replacement, Motherboard: adım 2, 1 resimden 1.
    • Remove the two plugs for the screen by pulling up and away from the motherboard.
  3. NuVision TM1088 Motherboard Replacement: adım 3, 1 resimden 1.
    • Remove the plug for the cameras by pulling the plug up and away from the motherboard.
  4. NuVision TM1088 Motherboard Replacement: adım 4, 1 resimden 1.
    • Melt solder and remove red and black wires leading to the battery.
  5. NuVision TM1088 Motherboard Replacement: adım 5, 1 resimden 1.
    • Melt the solder on the black and gray wires and remove wires from motherboard.
  6. NuVision TM1088 Motherboard Replacement: adım 6, 1 resimden 1.
    • Melt the solder and remove the red and black wires leading to the speaker.
  7. NuVision TM1088 Motherboard Replacement: adım 7, 1 resimden 1.
    • Remove the four 4 mm Phillips head screws holding in the motherboard.
  8. NuVision TM1088 Motherboard Replacement: adım 8, 1 resimden 1.
    • Lift the motherboard away from the front cover assembly.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Nathaniel Nasman
750 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 1-1, Miles Spring 2015 UMass Dartmouth, Team 1-1, Miles Spring 2015 üyesi
UMASSD-MILES-S15S1G1
3 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 4
Her zaman: 1,678
