Ana içeriğe geç
NuVision TM800A510L Rear Camera Replacement
  1. NuVision TM800A510L Rear Camera Replacement, Rear Camera: adım 1, 2 resimden 1. NuVision TM800A510L Rear Camera Replacement, Rear Camera: adım 1, 2 resimden 2.
    • Use a Heat Gun to heat the sides of the device one at a time. The Heat Gun will loosen the adhesive.
    • Use thin tools to pry the back of the device off.
    • Metal tools may work best but may also scratch the device. Plastic prying tools can also be used.
    • Be careful around the power and volume buttons.
  2. NuVision TM800A510L Rear Camera Replacement: adım 2, 1 resimden 1.
    • There are two different cameras and each have different ribbons.
    • Unlock both ribbons by flipping the black bar up.
  3. NuVision TM800A510L Rear Camera Replacement: adım 3, 2 resimden 1. NuVision TM800A510L Rear Camera Replacement: adım 3, 2 resimden 2.
    • The camera facing towards the table lifts out easily, so go ahead and take that one out.
    • This works out well, if this is the camera you are most concerned about.
    • If you are more concerned the one facing you, move on to the next step.
  4. NuVision TM800A510L Rear Camera Replacement: adım 4, 2 resimden 1. NuVision TM800A510L Rear Camera Replacement: adım 4, 2 resimden 2.
    • This camera is held down with adhesive, so you must be careful when prying it.
    • GO SLOW!
    • Camera pulls up and out of its slot easily.
Sonuç
Be advised that you will need to replace the adhesive.
Bir başkası bu kılavuzu tamamladı.
0 Comments
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 7
Her zaman: 340
