Ana içeriğe geç
Numark TT1600 Audio Jacks Replacement
Neye ihtiyacın var
  1. Numark TT1600 Audio Jacks Replacement, Audio Jacks: adım 1, 1 resimden 1.
    • Flip over the turntable and remove the nine screws on the outer edges.
  2. Numark TT1600 Audio Jacks Replacement: adım 2, 2 resimden 1. Numark TT1600 Audio Jacks Replacement: adım 2, 2 resimden 2.
    • Find the audio jacks located on the back side of the turntable.
    • Remove the screw located in between the right and left audio jacks.
  3. Numark TT1600 Audio Jacks Replacement: adım 3, 1 resimden 1.
    • Remove the back cover by pulling it apart.
  4. Numark TT1600 Audio Jacks Replacement: adım 4, 1 resimden 1.
    • Remove the grounding hardware located next to the audio jacks.
  5. Numark TT1600 Audio Jacks Replacement: adım 5, 2 resimden 1. Numark TT1600 Audio Jacks Replacement: adım 5, 2 resimden 2.
    • Remove the ground screw and washers.
  6. Numark TT1600 Audio Jacks Replacement: adım 6, 1 resimden 1.
    • Remove the remaining nut and washer.
  7. Numark TT1600 Audio Jacks Replacement: adım 7, 1 resimden 1.
    • Remove the screw located on the back panel of the audio jack housing.
  8. Numark TT1600 Audio Jacks Replacement: adım 8, 3 resimden 1. Numark TT1600 Audio Jacks Replacement: adım 8, 3 resimden 2. Numark TT1600 Audio Jacks Replacement: adım 8, 3 resimden 3.
    • Remove the screw that connects the audio jacks to the biggest circuit board via wire.
  9. Numark TT1600 Audio Jacks Replacement: adım 9, 1 resimden 1.
    • Gently pull out the audio input jacks from the audio input housing.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Nikolai
254 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 17-14, Regan Fall 2011 Cal Poly, Team 17-14, Regan Fall 2011 üyesi
CPSU-REGAN-F11S17G14
4 Üyeler
11 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 2
Her zaman: 1,379
