Ana içeriğe geç
Nutri Ninja Ninja Blender Duo BL641 Blade Replacement
Neye ihtiyacın var
  1. Nutri Ninja Ninja Blender Duo BL641 Blade Replacement, Blade: adım 1, 2 resimden 1. Nutri Ninja Ninja Blender Duo BL641 Blade Replacement, Blade: adım 1, 2 resimden 2.
    • Make sure blender is turned off.
    • Lift open the lid of blender by pressing the "Release" button and move to the side
  2. Nutri Ninja Ninja Blender Duo BL641 Blade Replacement: adım 2, 2 resimden 1. Nutri Ninja Ninja Blender Duo BL641 Blade Replacement: adım 2, 2 resimden 2.
    • Carefully Grab the top of the blade and pull upward with medium force.
    • The blade should slide out easily.
    • Do not touch the blades! Even when dull they can still cut you.
  3. Nutri Ninja Ninja Blender Duo BL641 Blade Replacement: adım 3, 2 resimden 1. Nutri Ninja Ninja Blender Duo BL641 Blade Replacement: adım 3, 2 resimden 2.
    • Carefully pick up the new blade and match the bottom star shaped opening to the star shaped protrusion from the blender.
  4. Nutri Ninja Ninja Blender Duo BL641 Blade Replacement: adım 4, 1 resimden 1.
    • Slowly connect the two star shapes together and push down until it reaches the bottom.
Sonuç
Now your blender can resume blending to perfection.
Charlotte
101 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team S7-G1, Banghart Fall 2017 Cal Poly, Team S7-G1, Banghart Fall 2017 üyesi
CPSU-BANGHART-F17S7G1
5 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 14
Son 30 gün: 44
Her zaman: 3,130
