Ana içeriğe geç
Nutri Ninja Ninja Blender Duo BL641 Power Cord Replacement
Neye ihtiyacın var
  1. Nutri Ninja Ninja Blender Duo BL641 Power Cord Replacement, Power Cord: adım 1, 2 resimden 1. Nutri Ninja Ninja Blender Duo BL641 Power Cord Replacement, Power Cord: adım 1, 2 resimden 2.
    • Unscrew the screws from the base of the blender (These should be 5 gauge phillips head screws).
    • 2 of the screws will be star shaped rather than phillips head.
    • Remove the base plate.
  2. Nutri Ninja Ninja Blender Duo BL641 Power Cord Replacement: adım 2, 2 resimden 1. Nutri Ninja Ninja Blender Duo BL641 Power Cord Replacement: adım 2, 2 resimden 2.
    • Identify the red and black wires topped with white-clear caps.
    • Use pliers to squeeze the flattened part of both caps.
    • The black and red wires attached to the power cord should be loose and ready to pull out.
  3. Nutri Ninja Ninja Blender Duo BL641 Power Cord Replacement: adım 3, 1 resimden 1.
    • Replace the cord by slipping the new cord's black and red wires into the caps.
    • Pinch the middle of the cap back to the flattened position using the pliers.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Allie Decker
125 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team S7-G1, Banghart Fall 2017 Cal Poly, Team S7-G1, Banghart Fall 2017 üyesi
CPSU-BANGHART-F17S7G1
5 Üyeler
6 adet Kılavuz yazıldı
2 Yorum
Como puedo extraer la parte donde sienta el vaso de mi licuadora ninja ct641
Memorex com - Yanıt
Como puedo extraer la base donde asienta el vaso de licuadora ninja ct641
Memorex com - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 11
Son 30 gün: 45
Her zaman: 3,648
