Ana içeriğe geç
Nutribullet Rx #NB-301 Drive Socket Replacement
Neye ihtiyacın var
  1. Nutribullet Rx #NB-301 Drive Socket Replacement, Drive Socket: adım 1, 3 resimden 1. Nutribullet Rx #NB-301 Drive Socket Replacement, Drive Socket: adım 1, 3 resimden 2. Nutribullet Rx #NB-301 Drive Socket Replacement, Drive Socket: adım 1, 3 resimden 3.
    • Make sure to unplug the device before you start the repair.
    • Flip the blender over so the bottom is facing up.
    • Use a Phillips #2 screwdriver to remove the four 10 mm screws from the base of the blender.
    • Remove the base cover from the blender.
  2. Nutribullet Rx #NB-301 Drive Socket Replacement: adım 2, 2 resimden 1. Nutribullet Rx #NB-301 Drive Socket Replacement: adım 2, 2 resimden 2.
    • Clamp down on the nut above the socket with the needle nose pliers so it stays in place for the next step.
  3. Nutribullet Rx #NB-301 Drive Socket Replacement: adım 3, 3 resimden 1. Nutribullet Rx #NB-301 Drive Socket Replacement: adım 3, 3 resimden 2. Nutribullet Rx #NB-301 Drive Socket Replacement: adım 3, 3 resimden 3.
    • Lay the blender on its side and hold the drive socket with the needle nose pliers to keep in from turning so you can remove the screw.
    • Use a Phillips #2 screwdriver to remove the screw securing the drive socket.
  4. Nutribullet Rx #NB-301 Drive Socket Replacement: adım 4, 3 resimden 1. Nutribullet Rx #NB-301 Drive Socket Replacement: adım 4, 3 resimden 2. Nutribullet Rx #NB-301 Drive Socket Replacement: adım 4, 3 resimden 3.
    • Remove the drive socket from the motor.
  5. Nutribullet Rx #NB-301 Drive Socket Replacement: adım 5, 3 resimden 1. Nutribullet Rx #NB-301 Drive Socket Replacement: adım 5, 3 resimden 2. Nutribullet Rx #NB-301 Drive Socket Replacement: adım 5, 3 resimden 3.
    • Remove all dust and residue from the area before you replace your new drive socket.
  6. Nutribullet Rx #NB-301 Drive Socket Replacement: adım 6, 3 resimden 1. Nutribullet Rx #NB-301 Drive Socket Replacement: adım 6, 3 resimden 2. Nutribullet Rx #NB-301 Drive Socket Replacement: adım 6, 3 resimden 3.
    • Use a Phillips #2 screwdriver to secure the drive socket to the motor.
  7. Nutribullet Rx #NB-301 Drive Socket Replacement: adım 7, 2 resimden 1. Nutribullet Rx #NB-301 Drive Socket Replacement: adım 7, 2 resimden 2.
    • Place the bottom cover back on the blender.
    • Use the Phillips #2 screwdriver to replace the four 10 mm screws on the back cover back.
Sonuç
Martin G
145 İtibar
1 Kılavuz yazıldı
Ekip
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 9
Son 30 gün: 58
Her zaman: 518
