Ana içeriğe geç
Nvidia Shield Controller Buttons Replacement
Neye ihtiyacın var
  1. Nvidia Shield Controller Buttons Replacement, Remove Front Panel: adım 1, 3 resimden 1. Nvidia Shield Controller Buttons Replacement, Remove Front Panel: adım 1, 3 resimden 2. Nvidia Shield Controller Buttons Replacement, Remove Front Panel: adım 1, 3 resimden 3.
    • Remove the seven 6.4mm T5 Torx screws from the back panel.
    • Use the spudger to separate the front and back panels.
    FixBot'a Sor
    Yorum Ekle
  2. Nvidia Shield Controller Buttons Replacement, Remove Green Grill: adım 2, 2 resimden 1. Nvidia Shield Controller Buttons Replacement, Remove Green Grill: adım 2, 2 resimden 2.
    • The green grill is not screwed in so it can be pulled right out.
    FixBot'a Sor
    Yorum Ekle
  3. Nvidia Shield Controller Buttons Replacement, Remove Battery Cables: adım 3, 3 resimden 1. Nvidia Shield Controller Buttons Replacement, Remove Battery Cables: adım 3, 3 resimden 2. Nvidia Shield Controller Buttons Replacement, Remove Battery Cables: adım 3, 3 resimden 3.
    • Remove the six 6.5mm T5 Torx screws.
    • Disconnect the power wires.
    • Peel back the copper tape and disconnect the black and white wires.
    FixBot'a Sor
    Yorum Ekle
  4. Nvidia Shield Controller Buttons Replacement, Remove Battery Apparatus: adım 4, 1 resimden 1.
    • Pull the battery apparatus out once all cables are removed.
    FixBot'a Sor
    Yorum Ekle
  5. Nvidia Shield Controller Buttons Replacement, Removing Button Board: adım 5, 3 resimden 1. Nvidia Shield Controller Buttons Replacement, Removing Button Board: adım 5, 3 resimden 2. Nvidia Shield Controller Buttons Replacement, Removing Button Board: adım 5, 3 resimden 3.
    • Remove seven 6.5 mm T5 torx screws from the button board.
    • Refer to the second image as some screws are not visible in the first image. One of these screws is covered by the orange ribbon.
    • Remove the button board.
    FixBot'a Sor
    Yorum Ekle
Sonuç
7 farklı kişi bu kılavuzu tamamladı.
Daniel Eberhart
379 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team 1-1, Hickman Fall 2014 USF Tampa, Team 1-1, Hickman Fall 2014 üyesi
USFT-HICKMAN-F14S1G1
4 Üyeler
18 adet Kılavuz yazıldı
2Kılavuz Yorumları
From where can I get the buttons?
Chirag Khatri - Yanıt Paylaş
Hey:) I am not sure
Knut Gunnar Walle - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 9
Son 30 gün: 68
Her zaman: 6,812
