Ana içeriğe geç
Nvidia Shield Controller Buttons Replacement
Neye ihtiyacın var
  1. Nvidia Shield Controller Buttons Replacement, Remove Front Panel: adım 1, 3 resimden 1. Nvidia Shield Controller Buttons Replacement, Remove Front Panel: adım 1, 3 resimden 2. Nvidia Shield Controller Buttons Replacement, Remove Front Panel: adım 1, 3 resimden 3.
    • Remove the seven 6.4mm T5 Torx screws from the back panel.
    • Use the spudger to separate the front and back panels.
    For the rubber screw covers, it is easiest to push at them at the top, otherwise you have the possibility of damaging the surrounding rubber.
    Any hints at getting the center plastic screw cover out?
    Miles Raymond - Yanıt
  2. Nvidia Shield Controller Buttons Replacement, Remove Green Grill: adım 2, 2 resimden 1. Nvidia Shield Controller Buttons Replacement, Remove Green Grill: adım 2, 2 resimden 2.
    • The green grill is not screwed in so it can be pulled right out.
  3. Nvidia Shield Controller Buttons Replacement, Remove Battery Cables: adım 3, 3 resimden 1. Nvidia Shield Controller Buttons Replacement, Remove Battery Cables: adım 3, 3 resimden 2. Nvidia Shield Controller Buttons Replacement, Remove Battery Cables: adım 3, 3 resimden 3.
    • Remove the six 6.5mm T5 Torx screws.
    • Disconnect the power wires.
    • Peel back the copper tape and disconnect the black and white wires.
  4. Nvidia Shield Controller Buttons Replacement, Remove Battery Apparatus: adım 4, 1 resimden 1.
    • Pull the battery apparatus out once all cables are removed.
  5. Nvidia Shield Controller Buttons Replacement, Removing Button Board: adım 5, 3 resimden 1. Nvidia Shield Controller Buttons Replacement, Removing Button Board: adım 5, 3 resimden 2. Nvidia Shield Controller Buttons Replacement, Removing Button Board: adım 5, 3 resimden 3.
    • Remove seven 6.5 mm T5 torx screws from the button board.
    • Refer to the second image as some screws are not visible in the first image. One of these screws is covered by the orange ribbon.
    • Remove the button board.
Sonuç
7 farklı kişi bu kılavuzu tamamladı.
Daniel Eberhart
379 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team 1-1, Hickman Fall 2014 USF Tampa, Team 1-1, Hickman Fall 2014 üyesi
USFT-HICKMAN-F14S1G1
4 Üyeler
18 adet Kılavuz yazıldı
2 Yorum
From where can I get the buttons?
Chirag Khatri - Yanıt
Hey:) I am not sure
Knut Gunnar Walle - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 7
Son 30 gün: 22
Her zaman: 6,032
