Ana içeriğe geç
Nvidia Shield Controller Motherboard Replacement
Neye ihtiyacın var
  1. Nvidia Shield Controller Motherboard Replacement, Motherboard: adım 1, 3 resimden 1. Nvidia Shield Controller Motherboard Replacement, Motherboard: adım 1, 3 resimden 2. Nvidia Shield Controller Motherboard Replacement, Motherboard: adım 1, 3 resimden 3.
    • Use a Torx TR6 screwdriver to remove the six 7mm screws from the back of the controller.
  2. Nvidia Shield Controller Motherboard Replacement: adım 2, 2 resimden 1. Nvidia Shield Controller Motherboard Replacement: adım 2, 2 resimden 2.
    • Use a plastic opening tool to pry open the back frame of the controller.
  3. Nvidia Shield Controller Motherboard Replacement: adım 3, 3 resimden 1. Nvidia Shield Controller Motherboard Replacement: adım 3, 3 resimden 2. Nvidia Shield Controller Motherboard Replacement: adım 3, 3 resimden 3.
    • Use the Torx TR6 bit to remove the two 7mm screws behind the analog sticks.
    • Unplug the power supply cable from the analog stick assembly.
  4. Nvidia Shield Controller Motherboard Replacement: adım 4, 3 resimden 1. Nvidia Shield Controller Motherboard Replacement: adım 4, 3 resimden 2. Nvidia Shield Controller Motherboard Replacement: adım 4, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Use a pair of tweezers to unplug the rumble motors from the motherboard.
    • Use a pair of tweezers to unplug the battery cable from the motherboard.
  5. Nvidia Shield Controller Motherboard Replacement: adım 5, 3 resimden 1. Nvidia Shield Controller Motherboard Replacement: adım 5, 3 resimden 2. Nvidia Shield Controller Motherboard Replacement: adım 5, 3 resimden 3.
    • Use a Torx TR6 screwdriver to remove the two 7mm screws towards the top of the frame.
    • Use the Torx T5 screwdriver to remove the two 5mm screws in the bottom corners of the frame.
    • Lift out the motherboard from the case.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 8
Son 30 gün: 21
Her zaman: 2,756
