Ana içeriğe geç
Nvidia Shield Fan Replacement
Neye ihtiyacın var
  1. Nvidia Shield Fan Replacement, Remove Front Panel: adım 1, 3 resimden 1. Nvidia Shield Fan Replacement, Remove Front Panel: adım 1, 3 resimden 2. Nvidia Shield Fan Replacement, Remove Front Panel: adım 1, 3 resimden 3.
    • Remove the seven 6.4mm T5 Torx screws from the back panel.
    • Use the spudger to separate the front and back panels.
    FixBot'a Sor
    Yorum Ekle
  2. Nvidia Shield Fan Replacement, Remove Green Grill: adım 2, 2 resimden 1. Nvidia Shield Fan Replacement, Remove Green Grill: adım 2, 2 resimden 2.
    • The green grill is not screwed in so it can be pulled right out.
    FixBot'a Sor
    Yorum Ekle
  3. Nvidia Shield Fan Replacement, Remove Battery Cables: adım 3, 3 resimden 1. Nvidia Shield Fan Replacement, Remove Battery Cables: adım 3, 3 resimden 2. Nvidia Shield Fan Replacement, Remove Battery Cables: adım 3, 3 resimden 3.
    • Remove the six 6.5mm T5 Torx screws.
    • Disconnect the power wires.
    • Peel back the copper tape and disconnect the black and white wires.
    FixBot'a Sor
    Yorum Ekle
  4. Nvidia Shield Fan Replacement, Remove Battery Apparatus: adım 4, 1 resimden 1.
    • Pull the battery apparatus out once all cables are removed.
    FixBot'a Sor
    Yorum Ekle
  5. Nvidia Shield Fan Replacement, Removing Fan: adım 5, 3 resimden 1. Nvidia Shield Fan Replacement, Removing Fan: adım 5, 3 resimden 2. Nvidia Shield Fan Replacement, Removing Fan: adım 5, 3 resimden 3.
    • Cooling is important for electronics, the last thing they want is to overheat.
    • Remove the two 7.3mm and four 8.4mm T5 Torx screws and disconnect the power cable.
    • Lift the fan free after the screws and cable are removed.
    FixBot'a Sor
    Yorum Ekle
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Marc Perez
545 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 1-1, Hickman Fall 2014 USF Tampa, Team 1-1, Hickman Fall 2014 üyesi
USFT-HICKMAN-F14S1G1
4 Üyeler
18 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 11
Son 30 gün: 61
Her zaman: 3,804
