Ana içeriğe geç
Nvidia Shield Pro Android TV Bottom Cover Replacement
Neye ihtiyacın var
  1. Nvidia Shield Pro Android TV Bottom Cover Replacement, Bottom Cover: adım 1, 2 resimden 1. Nvidia Shield Pro Android TV Bottom Cover Replacement, Bottom Cover: adım 1, 2 resimden 2.
    • Flip to the back side of your Nvidia Shield Pro Android TV.
    • To open the bottom cover of the Nvidia Shield, start from the corner and slide your plastic opening tool across the gap.
    • If using a plastic opening tool to open the bottom cover is difficult, try using a metal spudger.
Sonuç
Christian De Vera
167 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team S18-G2, White Winter 2020 Cal Poly, Team S18-G2, White Winter 2020 üyesi
CPSU-WHITE-W20S18G2
4 Üyeler
14 adet Kılavuz yazıldı
1Rehber Yorum
Hi, Shield Pro 2.
Remove 2 small cross head screws securing top cover to the back plate. Next you have to pry open the back edge and then slide the top cover forwards about 8mm away from the back plate to clear 3 catch points along each side.
S. Carter - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 22
Son 30 gün: 64
Her zaman: 2,792
