Ana içeriğe geç
Nvidia Shield Pro Android TV Controller D-Pad Replacement
Neye ihtiyacın var
  1. Nvidia Shield Pro Android TV Controller D-Pad Replacement, Bluetooth Controller D-Pad: adım 1, 3 resimden 1. Nvidia Shield Pro Android TV Controller D-Pad Replacement, Bluetooth Controller D-Pad: adım 1, 3 resimden 2. Nvidia Shield Pro Android TV Controller D-Pad Replacement, Bluetooth Controller D-Pad: adım 1, 3 resimden 3.
    • Remove the six T6 Torx screws from the back of the controller.
    FixBot'a Sor
    Yorum Ekle
  2. Nvidia Shield Pro Android TV Controller D-Pad Replacement: adım 2, 1 resimden 1.
    • Gently open the top frame of the cover with the plastic opening tool.
    FixBot'a Sor
    Yorum Ekle
  3. Nvidia Shield Pro Android TV Controller D-Pad Replacement: adım 3, 2 resimden 1. Nvidia Shield Pro Android TV Controller D-Pad Replacement: adım 3, 2 resimden 2.
    • Gently pull the wire connector out of its socket, separating the two halves of the controller.
    FixBot'a Sor
    Yorum Ekle
  4. Nvidia Shield Pro Android TV Controller D-Pad Replacement: adım 4, 1 resimden 1.
    • Remove the wire attached to the circular piece.
    FixBot'a Sor
    Yorum Ekle
  5. Nvidia Shield Pro Android TV Controller D-Pad Replacement: adım 5, 2 resimden 1. Nvidia Shield Pro Android TV Controller D-Pad Replacement: adım 5, 2 resimden 2.
    • Carefully remove the two T6 Torx screws from either side of the motherboard.
    FixBot'a Sor
    Yorum Ekle
  6. Nvidia Shield Pro Android TV Controller D-Pad Replacement: adım 6, 1 resimden 1.
    • Remove the yellow plug from its socket.
    FixBot'a Sor
    Yorum Ekle
  7. Nvidia Shield Pro Android TV Controller D-Pad Replacement: adım 7, 2 resimden 1. Nvidia Shield Pro Android TV Controller D-Pad Replacement: adım 7, 2 resimden 2.
    • Remove the two T6 Torx screws.
    FixBot'a Sor
    Yorum Ekle
  8. Nvidia Shield Pro Android TV Controller D-Pad Replacement: adım 8, 1 resimden 1.
    • Slowly pull up the primary circuit board of the controller until the D-pad is revealed.
    • Carefully remove the board.
    FixBot'a Sor
    Yorum Ekle
  9. Nvidia Shield Pro Android TV Controller D-Pad Replacement: adım 9, 1 resimden 1.
    • Gently remove and replace the D-Pad.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Ben Carrasco
347 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S18-G2, White Winter 2020 Cal Poly, Team S18-G2, White Winter 2020 üyesi
CPSU-WHITE-W20S18G2
4 Üyeler
14 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 11
Son 30 gün: 51
Her zaman: 2,258
