Ana içeriğe geç
Nvidia Shield Pro Android TV Fan/Heat Sink Replacement
Neye ihtiyacın var
  1. Nvidia Shield Pro Android TV Fan/Heat Sink Replacement, Bottom Cover: adım 1, 2 resimden 1. Nvidia Shield Pro Android TV Fan/Heat Sink Replacement, Bottom Cover: adım 1, 2 resimden 2.
    • Flip to the back side of your Nvidia Shield Pro Android TV.
    • To open the bottom cover of the Nvidia Shield, start from the corner and slide your plastic opening tool across the gap.
    • If using a plastic opening tool to open the bottom cover is difficult, try using a metal spudger.
    FixBot'a Sor
    Yorum Ekle
  2. Nvidia Shield Pro Android TV Fan/Heat Sink Replacement, Fan/Heat Sink: adım 2, 3 resimden 1. Nvidia Shield Pro Android TV Fan/Heat Sink Replacement, Fan/Heat Sink: adım 2, 3 resimden 2. Nvidia Shield Pro Android TV Fan/Heat Sink Replacement, Fan/Heat Sink: adım 2, 3 resimden 3.
    • Remove the five screws with a T6 Torx screwdriver.
    • Two of the screws are located directly on top of the fan/heat sink. The other three screws are located on a small triangle plate on the left side of the fan/heat sink.
    FixBot'a Sor
    Yorum Ekle
  3. Nvidia Shield Pro Android TV Fan/Heat Sink Replacement: adım 3, 2 resimden 1. Nvidia Shield Pro Android TV Fan/Heat Sink Replacement: adım 3, 2 resimden 2.
    • Once the screws are removed, gently detach the multi-colored wired connection from the motherboard.
    FixBot'a Sor
    Yorum Ekle
  4. Nvidia Shield Pro Android TV Fan/Heat Sink Replacement: adım 4, 1 resimden 1.
    • Gently remove the fan/heat sink out of the Nvidia Shield.
    FixBot'a Sor
    Yorum Ekle
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Jimmy Chen
753 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S18-G2, White Winter 2020 Cal Poly, Team S18-G2, White Winter 2020 üyesi
CPSU-WHITE-W20S18G2
4 Üyeler
14 adet Kılavuz yazıldı
7Kılavuz Yorumları
Hello can you tell me where to buy the fan and the plastic case opener?
Sajid Idrees - Yanıt Paylaş
From iFixit is generally the best for plastic spudgers/openers.
as for the fan apparently the Fan Model Number is BAZA0508R5U and there's plenty available on ebay and amazon.
Nic Ganglen - Yanıt Paylaş
My version had screws in the back which I had to remove, and then I could simply slide it away from the ports in the back to open it. The inside was completely different as well, but it's a pretty simple device.
John Doe - Yanıt Paylaş
This is the 500GB 2015 version they're showing.
Joseph Oliveira - Yanıt Paylaş
I have the Shield TV Pro Model: P2897 (2019 version)-> The latest model, even though it's 7 years old as of 2/1/25.
The pictures shown here looks nothing like the model I have.
You would think that even though these instructions provide detailed information on how to replace the abnormally noisy Fan that they would include information on what MODEL they're using here, unbelievable.
Proflex.Fitness - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 10
Son 7 gün: 58
Son 30 gün: 293
Her zaman: 17,485
