Ana içeriğe geç
Nvidia Shield Pro Android TV I/O Board Replacement
Neye ihtiyacın var
  1. Nvidia Shield Pro Android TV I/O Board Replacement, Bottom Cover: adım 1, 2 resimden 1. Nvidia Shield Pro Android TV I/O Board Replacement, Bottom Cover: adım 1, 2 resimden 2.
    • Flip to the back side of your Nvidia Shield Pro Android TV.
    • To open the bottom cover of the Nvidia Shield, start from the corner and slide your plastic opening tool across the gap.
    • If using a plastic opening tool to open the bottom cover is difficult, try using a metal spudger.
  2. Nvidia Shield Pro Android TV I/O Board Replacement, Hard Drive: adım 2, 3 resimden 1. Nvidia Shield Pro Android TV I/O Board Replacement, Hard Drive: adım 2, 3 resimden 2. Nvidia Shield Pro Android TV I/O Board Replacement, Hard Drive: adım 2, 3 resimden 3.
    • Remove the two pieces of adhesives found at the top and the bottom side of the hard drive.
    • Put the two adhesives aside. Make sure to keep them flat so that you can put them back on after.
  3. Nvidia Shield Pro Android TV I/O Board Replacement: adım 3, 3 resimden 1. Nvidia Shield Pro Android TV I/O Board Replacement: adım 3, 3 resimden 2. Nvidia Shield Pro Android TV I/O Board Replacement: adım 3, 3 resimden 3.
    • Detach the pack of wires by pulling it away from the socket.
  4. Nvidia Shield Pro Android TV I/O Board Replacement: adım 4, 3 resimden 1. Nvidia Shield Pro Android TV I/O Board Replacement: adım 4, 3 resimden 2. Nvidia Shield Pro Android TV I/O Board Replacement: adım 4, 3 resimden 3.
    • Next to the empty socket where the black wires were attached to the I/O board (refer back to Step 2), detach the plastic strap from the I/O board by pushing the strap away from the socket using your finger.
  5. Nvidia Shield Pro Android TV I/O Board Replacement: adım 5, 2 resimden 1. Nvidia Shield Pro Android TV I/O Board Replacement: adım 5, 2 resimden 2.
    • Remove the screw on the metal piece using a T6 Torx screwdriver and put away the metal piece after removing the screw.
  6. Nvidia Shield Pro Android TV I/O Board Replacement: adım 6, 1 resimden 1.
    • Gently pull the hard drive out of the device.
  7. Nvidia Shield Pro Android TV I/O Board Replacement, I/O Board: adım 7, 3 resimden 1. Nvidia Shield Pro Android TV I/O Board Replacement, I/O Board: adım 7, 3 resimden 2. Nvidia Shield Pro Android TV I/O Board Replacement, I/O Board: adım 7, 3 resimden 3.
    • Detach the brown side of the connector from the I/O board by pulling it upward.
    • Remove the screw from the silver plate using a T6 Torx screwdriver.
    • Put the cable aside after removing it.
  8. Nvidia Shield Pro Android TV I/O Board Replacement: adım 8, 2 resimden 1. Nvidia Shield Pro Android TV I/O Board Replacement: adım 8, 2 resimden 2.
    • Detach the small bundle of black wires from the I/O board by gently pulling upward.
    • Be very gentle because the wires are very fragile.
  9. Nvidia Shield Pro Android TV I/O Board Replacement: adım 9, 2 resimden 1. Nvidia Shield Pro Android TV I/O Board Replacement: adım 9, 2 resimden 2.
    • Remove the three T6 Torx screws from the I/O board.
  10. Nvidia Shield Pro Android TV I/O Board Replacement: adım 10, 3 resimden 1. Nvidia Shield Pro Android TV I/O Board Replacement: adım 10, 3 resimden 2. Nvidia Shield Pro Android TV I/O Board Replacement: adım 10, 3 resimden 3.
    • Detach the multi-colored (red/yellow/black) wire from the I/O board by pulling it away from the socket.
  11. Nvidia Shield Pro Android TV I/O Board Replacement: adım 11, 1 resimden 1.
    • Gently remove the I/O board by sliding it away from the exterior input/output sockets on your Nvidia Shield Pro.
Sonuç
8 farklı kişi bu kılavuzu tamamladı.
Jimmy Chen
717 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S18-G2, White Winter 2020 Cal Poly, Team S18-G2, White Winter 2020 üyesi
CPSU-WHITE-W20S18G2
4 Üyeler
14 adet Kılavuz yazıldı
2Kılavuz Yorumları
Where can I buy Nvidia Shield Pro Android TV I/O Board? Greentings from Brazil.
Sergio Santos - Yanıt
Aniyone managed to get a source for this part, The IO board
Yoda Mann - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 48
Son 30 gün: 158
Her zaman: 6,337
