Ana içeriğe geç
Nvidia Shield TV 1st Generation Controller Battery Replacement
Neye ihtiyacın var
  1. Nvidia Shield TV 1st Generation Controller Battery Replacement, Controller Battery: adım 1, 2 resimden 1. Nvidia Shield TV 1st Generation Controller Battery Replacement, Controller Battery: adım 1, 2 resimden 2.
    • Remove the indicated six screws using the T6 Torx screwdriver.
    FixBot'a Sor
    Yorum Ekle
  2. Nvidia Shield TV 1st Generation Controller Battery Replacement: adım 2, 2 resimden 1. Nvidia Shield TV 1st Generation Controller Battery Replacement: adım 2, 2 resimden 2.
    • Use the plastic opening tool to pry the face of the controller away from the body.
    • Make sure the controller is face down during this step as the buttons can easily fall out.
    FixBot'a Sor
    Yorum Ekle
  3. Nvidia Shield TV 1st Generation Controller Battery Replacement: adım 3, 1 resimden 1.
    • Carefully remove the indicated ribbon wires from the face of the controller.
    FixBot'a Sor
    Yorum Ekle
  4. Nvidia Shield TV 1st Generation Controller Battery Replacement: adım 4, 2 resimden 1. Nvidia Shield TV 1st Generation Controller Battery Replacement: adım 4, 2 resimden 2.
    Bu adımda kullanılan alet:
    $3.99
    • Use the angled tweezers to remove the vibration motor cable, moving it upward from its socket.
    • Lift the vibration motor out of the front case.
    • Repeat for the other side.
    • Use the angled tweezers to remove the battery cable, moving it upward from its socket.
    FixBot'a Sor
    Yorum Ekle
  5. Nvidia Shield TV 1st Generation Controller Battery Replacement: adım 5, 3 resimden 1. Nvidia Shield TV 1st Generation Controller Battery Replacement: adım 5, 3 resimden 2. Nvidia Shield TV 1st Generation Controller Battery Replacement: adım 5, 3 resimden 3.
    • Using the T6 Torx screwdriver, remove the indicated eight screws from the logic board.
    • Lift the logic board away from the front case.
    FixBot'a Sor
    Yorum Ekle
  6. Nvidia Shield TV 1st Generation Controller Battery Replacement: adım 6, 3 resimden 1. Nvidia Shield TV 1st Generation Controller Battery Replacement: adım 6, 3 resimden 2. Nvidia Shield TV 1st Generation Controller Battery Replacement: adım 6, 3 resimden 3.
    • Using the T6 Torx screwdriver, remove the indicated four screws from the panel.
    • Remove the panel from the front case.
    • Lift the battery from the front case to remove it.
    FixBot'a Sor
    Yorum Ekle
Sonuç
12 farklı kişi bu kılavuzu tamamladı.
Joshua Neally
581 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S16-G6, Eyestone Fall 2017 USF Tampa, Team S16-G6, Eyestone Fall 2017 üyesi
USFT-EYESTONE-F17S16G6
3 Üyeler
8 adet Kılavuz yazıldı
8Kılavuz Yorumları
Where can i buy the replacement Battery? What tags should i use to find it?
Rancid 3000a - Yanıt Paylaş
LC18650 Remote Control accu
djcornelissen - Yanıt Paylaş
Are battery packs available for the 2017 controller?
Andrew - Yanıt Paylaş
Simply reconnecting the battery fixed my issues
Charles Keisler - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 18
Son 30 gün: 87
Her zaman: 21,657
