Neye ihtiyacın var
Starting at the Micro SD Card Slot and using the blue plastic opening tool, begin to maneuver the tool around the edges while applying light pressure to lift the panel upwards.
Bu adımda kullanılan alet:Tweezers$3.99
Use the angled tweezers to disconnect the black power cable from the mother board. The Cable should pop up from its slot when pulled.
3 farklı kişi bu kılavuzu tamamladı.
1Rehber Yorum
Odd question for you. I'm replacing the antena in a nvidia shield as an experimant, as was wonder if you know what type of connecter is used on the cable to the pcb. I dont want to desoder the exsisting antenna if i can help it as they are calabrated.
