Ana içeriğe geç
Nvidia Shield Tablet Motherboard Replacement
Neye ihtiyacın var
  1. Nvidia Shield Tablet Motherboard Replacement, Rear Case: adım 1, 2 resimden 1. Nvidia Shield Tablet Motherboard Replacement, Rear Case: adım 1, 2 resimden 2.
    • First, remove the stylus from your tablet.
  2. Nvidia Shield Tablet Motherboard Replacement: adım 2, 3 resimden 1. Nvidia Shield Tablet Motherboard Replacement: adım 2, 3 resimden 2. Nvidia Shield Tablet Motherboard Replacement: adım 2, 3 resimden 3.
    Bu adımda kullanılan alet:
    Anti-Static Wrist Strap
    $7.95
    • Set the tablet so the buttons, microSD, and stylus port are facing you.
    • Open the microSD slot.
    • Using the flat end of the spudger tool, carefully pry open the case starting from the microSD slot, slowly sliding the spudger along the inside edge of the case.
    • You may want to put on your anti-static wrist strap at this point as the motherboard will be vulnerable to physical touch and electrostatic shock after the casing is removed.
  3. Nvidia Shield Tablet Motherboard Replacement: adım 3, 2 resimden 1. Nvidia Shield Tablet Motherboard Replacement: adım 3, 2 resimden 2.
    • As you remove your case, be aware of small clips along the edges.
    • Finally, set the old casing aside.
  4. Nvidia Shield Tablet Motherboard Replacement, Motherboard: adım 4, 1 resimden 1.
    $7.95
    • Carefully use the precision tweezers to unplug the ribbon cable.
    • Be sure to have your anti-static wrist strap on for this procedure.
  5. Nvidia Shield Tablet Motherboard Replacement: adım 5, 3 resimden 1. Nvidia Shield Tablet Motherboard Replacement: adım 5, 3 resimden 2. Nvidia Shield Tablet Motherboard Replacement: adım 5, 3 resimden 3.
    • Remove the two 6.5 mm Phillips #00 screws and seven 3.0 mm Phillips #00 screws.
  6. Nvidia Shield Tablet Motherboard Replacement: adım 6, 3 resimden 1. Nvidia Shield Tablet Motherboard Replacement: adım 6, 3 resimden 2. Nvidia Shield Tablet Motherboard Replacement: adım 6, 3 resimden 3.
    • Use a pair of tweezers to disconnect the three black antenna cables from the motherboard.
    • Use the flat end of the spudger tool to carefully pry up the motherboard.
    • In the first Shield, the stylus ribbon cable is located under the right side of board. While there are 2 additional cables for the cameras underneath the left end of the board. Be sure to loosen the cameras before lifting the board.
  7. Nvidia Shield Tablet Motherboard Replacement: adım 7, 2 resimden 1. Nvidia Shield Tablet Motherboard Replacement: adım 7, 2 resimden 2.
    • Desolder the positive and negative battery cables from the motherboard.
    • Make sure to note which wire goes where, you don't want to re-solder the wires backwards!
    • The motherboard should now come free.
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Molly Bauer
1.478 İtibar
6 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 2-2, Blackwell Fall 2015 USF Tampa, Team 2-2, Blackwell Fall 2015 üyesi
USFT-BLACKWELL-F15S2G2
3 Üyeler
11 adet Kılavuz yazıldı
9Kılavuz Yorumları
Where do you obtain a new motherboard?
imprintcave - Yanıt
The real question is more about how to find a new shield tablet motherboard ??
willixlive - Yanıt
where can i buy the motherboard
Gurjot Dhaliwal - Yanıt
waar kan ik een nieuw shield moederbord kopen?
tom1vangestel - Yanıt
Hello, I'm looking for a description of the various ribbon connectors on the motherboard.
I'm also looking for a hint to solve a problem I have after replacing the screen+digitizer: the right side (half) of the touch screen does'n work.
Laurent Zanoni - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 31
Her zaman: 9,814
