Ana içeriğe geç
Nvidia Shield Tablet Rear Case Replacement
Neye ihtiyacın var
  1. Nvidia Shield Tablet Rear Case Replacement, Rear Case: adım 1, 2 resimden 1. Nvidia Shield Tablet Rear Case Replacement, Rear Case: adım 1, 2 resimden 2.
    • First, remove the stylus from your tablet.
  2. Nvidia Shield Tablet Rear Case Replacement: adım 2, 3 resimden 1. Nvidia Shield Tablet Rear Case Replacement: adım 2, 3 resimden 2. Nvidia Shield Tablet Rear Case Replacement: adım 2, 3 resimden 3.
    Bu adımda kullanılan alet:
    Anti-Static Wrist Strap
    $7.95
    • Set the tablet so the buttons, microSD, and stylus port are facing you.
    • Open the microSD slot.
    • Using the flat end of the spudger tool, carefully pry open the case starting from the microSD slot, slowly sliding the spudger along the inside edge of the case.
    • You may want to put on your anti-static wrist strap at this point as the motherboard will be vulnerable to physical touch and electrostatic shock after the casing is removed.
  3. Nvidia Shield Tablet Rear Case Replacement: adım 3, 2 resimden 1. Nvidia Shield Tablet Rear Case Replacement: adım 3, 2 resimden 2.
    • As you remove your case, be aware of small clips along the edges.
    • Finally, set the old casing aside.
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Molly Bauer
1.478 İtibar
6 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 2-2, Blackwell Fall 2015 USF Tampa, Team 2-2, Blackwell Fall 2015 üyesi
USFT-BLACKWELL-F15S2G2
3 Üyeler
11 adet Kılavuz yazıldı
1Rehber Yorum
I snapped the cable of the dabbler on the rear case coz i didnt know there was one!
Anyone knows where can i get a new one?
damjannedelkovski - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 29
Her zaman: 3,624
