Ana içeriğe geç
Nvidia Shield Tablet Speaker Replacement
Neye ihtiyacın var
    1. Nvidia Shield Tablet Speaker Replacement, Rear Case: adım 1, 2 resimden 1. Nvidia Shield Tablet Speaker Replacement, Rear Case: adım 1, 2 resimden 2.
      • First, remove the stylus from your tablet.
      FixBot'a Sor
      Yorum Ekle
    2. Nvidia Shield Tablet Speaker Replacement: adım 2, 3 resimden 1. Nvidia Shield Tablet Speaker Replacement: adım 2, 3 resimden 2. Nvidia Shield Tablet Speaker Replacement: adım 2, 3 resimden 3.
      Bu adımda kullanılan alet:
      Anti-Static Wrist Strap
      $7.95
      • Set the tablet so the buttons, microSD, and stylus port are facing you.
      • Open the microSD slot.
      • Using the flat end of the spudger tool, carefully pry open the case starting from the microSD slot, slowly sliding the spudger along the inside edge of the case.
      • You may want to put on your anti-static wrist strap at this point as the motherboard will be vulnerable to physical touch and electrostatic shock after the casing is removed.
      FixBot'a Sor
      Yorum Ekle
    3. Nvidia Shield Tablet Speaker Replacement: adım 3, 2 resimden 1. Nvidia Shield Tablet Speaker Replacement: adım 3, 2 resimden 2.
      • As you remove your case, be aware of small clips along the edges.
      • Finally, set the old casing aside.
      FixBot'a Sor
      Yorum Ekle
    1. Nvidia Shield Tablet Speaker Replacement, Speaker: adım 4, 1 resimden 1.
      • Orient your tablet so that the top of the tablet is furthest away from you.
      • Locate the top speaker, a black semi-rectangular piece on the top right side of the tablet.
      FixBot'a Sor
      Yorum Ekle
    2. Nvidia Shield Tablet Speaker Replacement: adım 5, 1 resimden 1.
      • Remove the two 3.0 mm Phillips #00 screws securing the speaker.
      FixBot'a Sor
      Yorum Ekle
    3. Nvidia Shield Tablet Speaker Replacement: adım 6, 3 resimden 1. Nvidia Shield Tablet Speaker Replacement: adım 6, 3 resimden 2. Nvidia Shield Tablet Speaker Replacement: adım 6, 3 resimden 3.
      • Gently pry the speaker up with the flat end of a spudger.
      • Use a plastic opening tool to peel up the tape covering the speaker wire.
      FixBot'a Sor
      Yorum Ekle
    4. Nvidia Shield Tablet Speaker Replacement: adım 7, 2 resimden 1. Nvidia Shield Tablet Speaker Replacement: adım 7, 2 resimden 2.
      $7.95
      • Next, with a gentle but firm grip, pull the audio input ribbon with the precision tweezers.
      • Finally, unplug the power source from your speaker using the precision tweezers.
      • Make sure you are using your anti-static wrist strap.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Molly Bauer
1.478 İtibar
6 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 2-2, Blackwell Fall 2015 USF Tampa, Team 2-2, Blackwell Fall 2015 üyesi
USFT-BLACKWELL-F15S2G2
3 Üyeler
11 adet Kılavuz yazıldı
1Rehber Yorum
This didn't work
Riley Schork - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 9
Son 30 gün: 49
Her zaman: 3,176
