Ana içeriğe geç
Nvidia Shield Tablet Touchscreen Controller Replacement
Arşivlenmiş Kılavuz
Bu kılavuz sadece arşivsel amaçlarla muhafaza edilmiştir. Onarımınızı gerçekleştirmek için kılavuzun güncel halini kullanın.
Neye ihtiyacın var
    1. Nvidia Shield Tablet Touchscreen Controller Replacement, Rear Case: adım 1, 2 resimden 1. Nvidia Shield Tablet Touchscreen Controller Replacement, Rear Case: adım 1, 2 resimden 2.
      • First, remove the stylus from your tablet.
      FixBot'a Sor
      Yorum Ekle
    2. Nvidia Shield Tablet Touchscreen Controller Replacement: adım 2, 3 resimden 1. Nvidia Shield Tablet Touchscreen Controller Replacement: adım 2, 3 resimden 2. Nvidia Shield Tablet Touchscreen Controller Replacement: adım 2, 3 resimden 3.
      Bu adımda kullanılan alet:
      Anti-Static Wrist Strap
      $7.95
      • Set the tablet so the buttons, microSD, and stylus port are facing you.
      • Open the microSD slot.
      • Using the flat end of the spudger tool, carefully pry open the case starting from the microSD slot, slowly sliding the spudger along the inside edge of the case.
      • You may want to put on your anti-static wrist strap at this point as the motherboard will be vulnerable to physical touch and electrostatic shock after the casing is removed.
      FixBot'a Sor
      Yorum Ekle
    3. Nvidia Shield Tablet Touchscreen Controller Replacement: adım 3, 2 resimden 1. Nvidia Shield Tablet Touchscreen Controller Replacement: adım 3, 2 resimden 2.
      • As you remove your case, be aware of small clips along the edges.
      • Finally, set the old casing aside.
      FixBot'a Sor
      Yorum Ekle
    1. Nvidia Shield Tablet Touchscreen Controller Replacement, Touchscreen Controller: adım 4, 2 resimden 1. Nvidia Shield Tablet Touchscreen Controller Replacement, Touchscreen Controller: adım 4, 2 resimden 2.
      $7.95
      • Peel away the tape covering the top right side of the motherboard. The plastic opening tools are useful in nudging the tape off.
      • Make sure you are using your anti-static wrist strap.
      FixBot'a Sor
      Yorum Ekle
    2. Nvidia Shield Tablet Touchscreen Controller Replacement: adım 5, 2 resimden 1. Nvidia Shield Tablet Touchscreen Controller Replacement: adım 5, 2 resimden 2.
      • Using the precision tweezers, gently remove the touchscreen controller from its port.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Molly Bauer
1.478 İtibar
6 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 2-2, Blackwell Fall 2015 USF Tampa, Team 2-2, Blackwell Fall 2015 üyesi
USFT-BLACKWELL-F15S2G2
3 Üyeler
11 adet Kılavuz yazıldı
4Kılavuz Yorumları
how to change this controller ???? he is not removable !!! where to buy it?
Tom - Yanıt Paylaş
How are you supposed to replace this part if it's connected to the Touchscreen panel by a flat ribbon cable. The pictures show the touchscreen controller that has been severed/cut by where the flat cable goes 90 degrees towards the touchscreen, you cannot just replace this part by itself as shown in the pictures. WTF????
Luis Nido - Yanıt Paylaş
My Thoughts exactly. Mine has one connector that is easily removed, the smaller end. The large wide end is up under a metal frame. I gave a gentle tug, but apparently its glued or sealed. Now to figure out how to remove it. Guessing a heat gun to the glass is the easiest way? No coming apart from the back/inside!
The Watson - Yanıt Paylaş
why is this still up. you can’t replace this part so the title is misleading. This part is torn easy you must remove the board from the tablet with the touch cable connector unlatched but the cable still in. if you try to bull it out first it rips.
MYdeviceRepair - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 13
Son 30 gün: 37
Her zaman: 3,554
