Giriş
The extending antennas at the top of the OLPC are crucial to receiving a wireless signal. Use this guide to replace faulty antennas and regain connectivity.
Neye ihtiyacın var
Turn the laptop so it is resting on its bottom.
Open the laptop by rotating the green wings on the side up, then lifting the top half of the laptop.
Rotate the top half of the laptop about 90 degrees.
Remove the four 4mm Phillips #1 screws that hold the top cover to the case.
Disconnect the five cables that connect the motherboard to the case by pulling them straight out of their sockets.
Lift the antennas and their hinges out of the case.
Pull the antenna away from the device to pull the cable through the channels it's routed through.
