Neye ihtiyacın var
Using the Phillips screwdriver, unscrew the 5 size M2 x .4 x 4mm screws underneath the battery.
Turn the bottom half with the keyboard upside down.
Lift the black tab up to free the ribbon cable.
Carefully pull the ribbon cable out from the connector.
2 farklı kişi bu kılavuzu tamamladı.
2 Yorum
Step #15 is wrong, disconnect the right blue cable instead of the left.
This also works on the XO-1
