Ana içeriğe geç
OLPC XO-1.5 Screen Portion Replacement
Neye ihtiyacın var
  1. OLPC XO-1.5 Screen Portion Replacement, Battery: adım 1, 1 resimden 1.
    • Place the laptop upside down with the handle away from you.
  2. OLPC XO-1.5 Screen Portion Replacement: adım 2, 1 resimden 1.
    • Slide the tabs out, towards the green edges, to show the open lock symbol.
    • The right tab will stay in place, but the left tab must be held in position while you remove the battery.
  3. OLPC XO-1.5 Screen Portion Replacement: adım 3, 3 resimden 1. OLPC XO-1.5 Screen Portion Replacement: adım 3, 3 resimden 2. OLPC XO-1.5 Screen Portion Replacement: adım 3, 3 resimden 3.
    • Lift the middle of the battery to remove it.
  4. OLPC XO-1.5 Screen Portion Replacement, Screen Portion: adım 4, 1 resimden 1.
    • Using the Phillips screwdriver, unscrew the 5 size M2 x .4 x 4mm screws underneath the battery.
  5. OLPC XO-1.5 Screen Portion Replacement: adım 5, 1 resimden 1.
    • Turn the laptop so that the red XO symbol is right side up.
    • Pull off the white plastic panel with your fingers. There will be 4 tabs that hold the white panel in place. It will require moderate force to remove.
    • If you are having difficulty pulling off the white plastic panel, use a spudger.
  6. OLPC XO-1.5 Screen Portion Replacement: adım 6, 1 resimden 1.
    • Unscrew the 4 size M2 x .4 x 4mm screws that are connected to the green plastic.
  7. OLPC XO-1.5 Screen Portion Replacement: adım 7, 1 resimden 1.
    • Unplug the white connector with black cables on each end on the left of the hinge.
  8. OLPC XO-1.5 Screen Portion Replacement: adım 8, 1 resimden 1.
    • Using the Phillips screwdriver, unscrew the 4 size M3 x .5 x 5mm screws holding the metal to the rest of the laptop.
  9. OLPC XO-1.5 Screen Portion Replacement: adım 9, 1 resimden 1.
    • Carefully lift the top half that has the screen away from the bottom half.
    • There is still one black cable connecting the two halves. Be sure not to break it.
  10. OLPC XO-1.5 Screen Portion Replacement: adım 10, 2 resimden 1. OLPC XO-1.5 Screen Portion Replacement: adım 10, 2 resimden 2.
    • Rotate the laptop 180 degrees so that the XO logo is now upside down.
    • Remove the center part of green handle. Push the white plastic back cover down away from the keyboard and top half. This should separate easily from the rest of the device.
  11. OLPC XO-1.5 Screen Portion Replacement: adım 11, 1 resimden 1.
    • Turn the laptop upside down, exposing the bottom inside of the keyboard.
    • This is similar to how the laptop was positioned when removing the battery, except now the white panel is gone.
  12. OLPC XO-1.5 Screen Portion Replacement: adım 12, 1 resimden 1.
    • Slide the black cable (the one that holds the two halves together) out of its connector.
  13. OLPC XO-1.5 Screen Portion Replacement: adım 13, 2 resimden 1. OLPC XO-1.5 Screen Portion Replacement: adım 13, 2 resimden 2.
    • Separate the screen portion from the rest of the laptop.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Sam Clark
61 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 3-19, Amido Fall 2012 Cal Poly, Team 3-19, Amido Fall 2012 üyesi
CPSU-AMIDO-F12S3G19
6 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 2
Her zaman: 1,049
