Ana içeriğe geç
Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
OLPC XO-4 Touch Keyboard Replacement
Neye ihtiyacın var
  1. OLPC XO-4 Touch Keyboard Replacement, Battery: adım 1, 1 resimden 1.
    • Turn the laptop upside-down, with the handle facing away from you.
  2. OLPC XO-4 Touch Keyboard Replacement: adım 2, 2 resimden 1. OLPC XO-4 Touch Keyboard Replacement: adım 2, 2 resimden 2.
    • Pull the lock tabs towards the green outer edges of the laptop.
    • Hold the left lock tab in the unlock position until the battery is completely removed in the next step.
  3. OLPC XO-4 Touch Keyboard Replacement: adım 3, 2 resimden 1. OLPC XO-4 Touch Keyboard Replacement: adım 3, 2 resimden 2.
    • Lift up on the middle of the battery to remove it from the device.
  4. OLPC XO-4 Touch Keyboard Replacement, Keyboard: adım 4, 2 resimden 1. OLPC XO-4 Touch Keyboard Replacement, Keyboard: adım 4, 2 resimden 2.
    • Remove the two 2mm Phillips #1 screws from beneath the battery lock tabs.
  5. OLPC XO-4 Touch Keyboard Replacement: adım 5, 3 resimden 1. OLPC XO-4 Touch Keyboard Replacement: adım 5, 3 resimden 2. OLPC XO-4 Touch Keyboard Replacement: adım 5, 3 resimden 3.
    • Flip the laptop over to its normal position.
    • Lift the two antennas on both sides to unlock the screen.
    • Open the laptop.
  6. OLPC XO-4 Touch Keyboard Replacement: adım 6, 2 resimden 1. OLPC XO-4 Touch Keyboard Replacement: adım 6, 2 resimden 2.
    • Be careful not to pull the keyboard too far because there is still a ribbon cable attached to the bottom.
    • Gently lift up on the back of the keyboard.
    • Pull the keyboard up far enough to expose the ribbon cable.
  7. OLPC XO-4 Touch Keyboard Replacement: adım 7, 2 resimden 1. OLPC XO-4 Touch Keyboard Replacement: adım 7, 2 resimden 2.
    • Gently lift up on the black connector to release the ribbon cable.
    • Gently pull the blue plastic tab up and away from the black connector.
    • Remove the keyboard from the laptop.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Michael Kellerman
58 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 3-30, Amido Winter 2013 Cal Poly, Team 3-30, Amido Winter 2013 üyesi
CPSU-AMIDO-W13S3G30
3 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 7
Her zaman: 883
