Giriş
Learn how to replace the motherboard on the OLPC XO-4 Touch.
Neye ihtiyacın var
Remove the two 4mm Phillips #1 screws underneath the screen on the right-hand side.
Rotate the screen 180° and remove the other two screws.
Gently pull out the two antenna connectors by pulling them away from the motherboard.
Remove the four black 4mm screws from the metal cover using a Phillips #1 screwdriver.
Remove the metal cover from the laptop.
Bir başkası bu kılavuzu tamamladı.
