Ana içeriğe geç
OLPC XO-4 Touch Power Button Replacement
Neye ihtiyacın var
  1. OLPC XO-4 Touch Power Button Replacement, Battery: adım 1, 1 resimden 1.
    • Turn the laptop upside-down, with the handle facing away from you.
  2. OLPC XO-4 Touch Power Button Replacement: adım 2, 2 resimden 1. OLPC XO-4 Touch Power Button Replacement: adım 2, 2 resimden 2.
    • Pull the lock tabs towards the green outer edges of the laptop.
    • Hold the left lock tab in the unlock position until the battery is completely removed in the next step.
  3. OLPC XO-4 Touch Power Button Replacement: adım 3, 2 resimden 1. OLPC XO-4 Touch Power Button Replacement: adım 3, 2 resimden 2.
    • Lift up on the middle of the battery to remove it from the device.
  4. OLPC XO-4 Touch Power Button Replacement, Screen Frame: adım 4, 3 resimden 1. OLPC XO-4 Touch Power Button Replacement, Screen Frame: adım 4, 3 resimden 2. OLPC XO-4 Touch Power Button Replacement, Screen Frame: adım 4, 3 resimden 3.
    • Remove the two 4mm Phillips #1 screws underneath the screen on the right-hand side.
    • Rotate the screen 180° and remove the other two screws.
    • You will have to put your screwdriver through the handle in order to reach the middle screw for both sides.
  5. OLPC XO-4 Touch Power Button Replacement: adım 5, 3 resimden 1. OLPC XO-4 Touch Power Button Replacement: adım 5, 3 resimden 2. OLPC XO-4 Touch Power Button Replacement: adım 5, 3 resimden 3.
    • Remove the green side panel by pressing down on the small green button on the top and sliding the panel up.
    • Repeat the step above for the panel on the other side.
  6. OLPC XO-4 Touch Power Button Replacement: adım 6, 1 resimden 1.
    • Be careful not to pull the bottom too far out because a ribbon cable is under the frame and can easily break.
    • Gently lift up the lower part of the frame and pull it down to free the screen frame.
  7. OLPC XO-4 Touch Power Button Replacement: adım 7, 2 resimden 1. OLPC XO-4 Touch Power Button Replacement: adım 7, 2 resimden 2.
    • Lift the black connector and pull the ribbon cable out by the purple tab, freeing the frame.
  8. OLPC XO-4 Touch Power Button Replacement, Screen: adım 8, 1 resimden 1.
    • Remove the four 7.62mm screws using a Phillips #1 screwdriver.
  9. OLPC XO-4 Touch Power Button Replacement: adım 9, 2 resimden 1. OLPC XO-4 Touch Power Button Replacement: adım 9, 2 resimden 2.
    • Be careful not to pull the screen out too far. There are two ribbon cables attached to the screen, and they can easily break.
    • Carefully lift the screen out.
  10. OLPC XO-4 Touch Power Button Replacement: adım 10, 3 resimden 1. OLPC XO-4 Touch Power Button Replacement: adım 10, 3 resimden 2. OLPC XO-4 Touch Power Button Replacement: adım 10, 3 resimden 3.
    • Notice that the laptop in this picture has been turned 180° with the antennas now below the screen.
    • For each ribbon cable, lift up the black connector and gently pull the ribbon cables out by the plastic tabs.
  11. OLPC XO-4 Touch Power Button Replacement: adım 11, 1 resimden 1.
    • Remove the screen from the laptop.
  12. OLPC XO-4 Touch Power Button Replacement, Back Cover: adım 12, 1 resimden 1.
    • Remove the four 6mm screws using a Phillips #1 screwdriver.
  13. OLPC XO-4 Touch Power Button Replacement: adım 13, 2 resimden 1. OLPC XO-4 Touch Power Button Replacement: adım 13, 2 resimden 2.
    • Rotate the top half of the laptop so that the back cover is facing you.
    • Pull up the tabs on the lower part of the back cover and pull it down and away from the antennas.
    • Remove the back cover by gently lifting it off of the laptop.
  14. OLPC XO-4 Touch Power Button Replacement, Wireless Card: adım 14, 3 resimden 1. OLPC XO-4 Touch Power Button Replacement, Wireless Card: adım 14, 3 resimden 2. OLPC XO-4 Touch Power Button Replacement, Wireless Card: adım 14, 3 resimden 3.
    • When pulling out the connectors, make sure to hold the metal connector instead of the wire.
    • Gently pull out the two antenna connectors by pulling them away from the motherboard.
  15. OLPC XO-4 Touch Power Button Replacement: adım 15, 1 resimden 1.
    • Remove the black 4mm Phillips #1 screw holding the wireless card in.
  16. OLPC XO-4 Touch Power Button Replacement: adım 16, 2 resimden 1. OLPC XO-4 Touch Power Button Replacement: adım 16, 2 resimden 2.
    • Remove the wireless card from the laptop by gently sliding it out of its socket.
  17. OLPC XO-4 Touch Power Button Replacement, Motherboard: adım 17, 3 resimden 1. OLPC XO-4 Touch Power Button Replacement, Motherboard: adım 17, 3 resimden 2. OLPC XO-4 Touch Power Button Replacement, Motherboard: adım 17, 3 resimden 3.
    • Remove the four black 4mm screws from the metal cover using a Phillips #1 screwdriver.
    • Remove the metal cover from the laptop.
  18. OLPC XO-4 Touch Power Button Replacement: adım 18, 3 resimden 1. OLPC XO-4 Touch Power Button Replacement: adım 18, 3 resimden 2. OLPC XO-4 Touch Power Button Replacement: adım 18, 3 resimden 3.
    • Pull the connectors out by holding the plastic tabs and not the wires.
    • Unplug the three wires connecting the motherboard to the bottom half of the laptop.
    • Unplug the two speaker wires from the motherboard.
  19. OLPC XO-4 Touch Power Button Replacement: adım 19, 3 resimden 1. OLPC XO-4 Touch Power Button Replacement: adım 19, 3 resimden 2. OLPC XO-4 Touch Power Button Replacement: adım 19, 3 resimden 3.
    • Turn the device over to where the screen used to be.
    • Pull out ribbon cable by holding the purple plastic tab.
    • Pull out connector with the black and white wire by holding plastic tab.
  20. OLPC XO-4 Touch Power Button Replacement: adım 20, 2 resimden 1. OLPC XO-4 Touch Power Button Replacement: adım 20, 2 resimden 2.
    • Move the motherboard slightly to the left so that the audio input and output jacks are out of the frame.
    • Pull the motherboard out of the laptop.
  21. OLPC XO-4 Touch Power Button Replacement, Power Button: adım 21, 2 resimden 1. OLPC XO-4 Touch Power Button Replacement, Power Button: adım 21, 2 resimden 2.
    • Remove the power button by pinching in the four tabs until the power button can be pushed out.
Sonuç
Matthew Smith
23 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 3-29, Amido Winter 2013 Cal Poly, Team 3-29, Amido Winter 2013 üyesi
CPSU-AMIDO-W13S3G29
4 Üyeler
20 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 2
Her zaman: 224
